Call forward or call divert,
the
same features just different names in some models of phones. Only the
name of the service says that it is diverting calls. There is 4
situations for activation and can be activated via the mobile device or
directly by entering codes on the display phone. The function codes and
their ability to use depends on the network operator.
Codes:
** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally
##21# ok, yes or call it will deactivate this divert.
*#21# ok, yes or call it will check status.
** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call
##61# ok, yes or call it will deactivate this divert.
*#61# ok, yes or call it will check status.
** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy
##67# ok, yes or call it will deactivate this divert.
*#67# ok, yes or call it will check status.
** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert.
*#62# ok, yes or call it will check status.
##002# ok, yes or call it will deactivate all divert.
If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls.
This service is not free, and you must contact your network operator for prices.
By!!!
Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
Switch on the "Call Forwarding" slider. The default position is off.
Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
