20 Most Recent
LG VX5200 Cellular Phone Questions & Answers
How do I erase the memory of my lg vx5200 cell
Allows you to erase all of your Contacts at once;
1. Press OK (MENU), press RIGHT ARROW two times, press 5 two times .
2. Enter the four-digit lock code.
3. Press 4 (Erase Contacts).
4. Select Yes then press OK.
Reset to Factory Default Settings:
1. Press MENU, RIGH ARROW two times, then 5 two times .
3. Press 5 (Reset Default).
4. Press OK, select Revert then press OK.
6/30/2015 10:03:12 AM •
LG VX5200...
Answered
on Jun 30, 2015
LG VX 5200 - Permanent Blue screen Display Problem
I had the same problem and just fixed it, literally five minutes ago. You'll have to be a little brave and sure of yourself because it involves taking the phone apart. Around the inside screen are four silver cushion/spongy pieces. Remove these with a very small flathead screwdriver and set aside. Now you will need a very small Phillips head screwdriver to remove the four screws that are underneath these cushions. Once they are removed very carefully use the flathead screwdriver to "crack" open the phone housing. Once it is opened you will see a gold/tan colored ribbon coming from the lower half of the phone. All you have to do is press down on this ribbon to make sure that it is connected to where it is supposed to connect. It's like a puzzle piece that has to fit perfectly in order for the screen to work properly. You can check to see if it's working by turning the phone on before replacing the housing. If it is not recheck the "puzzle piece." I hope this helps.
3/27/2015 4:55:05 PM •
LG VX5200...
Answered
on Mar 27, 2015
Lg spectrum shows security error
In this video we teach solve the problem Security Error on LG devices. is very easy to repair. repair security error lg phones easily. With few steps you will have your smartphone lg optimus repaired. unbrick lg optimus easy . Copy and paste this link into your browser: youtu.be/r5f-9uvu4Tk
Goof Luck ">
5/22/2014 8:12:21 PM •
LG VX5200...
Answered
on May 22, 2014
Can't find the MEID#
Most of the phones have info on about just go to settings and scroll down to about the phone you will find the serial number there if you cannot find it then dial *#06# you will find it! good luck my friend.
4/9/2014 4:42:33 AM •
LG VX5200...
Answered
on Apr 09, 2014
How to retrive a lock code
you can try to do *22899 which will sometimes reset it to the last four of your phone number
if this does not work, take it to the verizon store and ask a rep to hook it up to the PST machine and get the code for you, please find a knowledgeable rep to do this
2/9/2014 8:08:22 AM •
LG VX5200...
Answered
on Feb 09, 2014
Cell phone won't turn on
From what I have determined from tinkering with it, the problem is the Display connections.
It appears that the connection sockets are simply weak and do bit "snap" a they should.
My answer thus far is pretty easy. Open the phone, place the upper display side flat on a piece of cloth or something else thin but not course in order to prevent scuff marks. Now firmly hit/slap down on the back side of the face plate to insure it and the pieces inside it are in place and secure. works well for me, just ask the phone :-)
2/20/2013 6:36:05 PM •
LG VX5200...
Answered
on Feb 20, 2013
HOW TO RESET
- Press OK key for MENU, Right Navigation key two times, 5 key, 5 key.
- Enter 4 digit lock code. The default lock code is the last 4 digits of your phone number.
- Press 5 key (Reset Default).
- Press OK key, select Revert and then press OK key.
12/21/2012 8:35:59 PM •
LG VX5200...
Answered
on Dec 21, 2012
How to unlock a phone
hi,you have to provide the IMEI no. written on the back inside of your phone below the battery. There are serveral website but you have to pay them.like,http://unlocking.bz/sim-lock/5/Unlock_by_code_for_any_LG/best of luck!
2/12/2012 9:00:45 AM •
LG VX5200...
Answered
on Feb 12, 2012
My phone won't turn on.
Happened to Me Too , all you gotta do is like charge it for literally a day , and maybe a night ; in other words let it charge for a really long time NOT just 3-4 hours .
8/16/2011 4:02:10 AM •
LG VX5200...
Answered
on Aug 16, 2011
