20 Most Recent
HTC Tattoo Cell Phone Questions & Answers
How do i send and recieve music using bluetooth
Dear sir for sending or receiving the music via bluetooth, first of all you have to turn on the bluetooth.
1. Tap on start.
2. Select programs
3. Tap Comm manager
4. Click on Bluetooth to turn it on.
Once the bluetooth is on close the Comm Manager screen and leave the Programs window open.
5. Find the music files on your phone. Usually they are on File Explorer.
You can find File Explorer in Programs screen.
6. If the songs are in your memory card, select Storage Card from drop down list and find the song in its specific folder.
7. Select the song you would like to send.
8. Click on Menu and tap on 'Beam File...'.
9. It will search for other Bluetooth device. Once the device is found, send the file.
Once the file sending is done you will get notification and you can also check on other device.
For receiving the music file via Blueetooth, just follow the first 4 steps.
I hope these steps will help you. Do write back and let me and other know how did you you go.
Thank you
Regards
Fahad
The screen is black with no response. Thought it
Hello Mr Adrian,The problem with your phone seems to be the battery or it must be a problem with the circuit board.i would like to advice you to visit the nearest HTC service center as in both cases problem cannot be solved by yourself.Please vote me if i had helped.thank you with regardsMANI
I can't send text message on my htc tattoo mobile phone
for sending text messages :1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
Htc tattoo turns off on its own
HiThis is something I have experience with.It did not change until I started changing batteries more often then he (the phone) started to behave proprly again.All the bestKolbrun
