20 Most Recent HTC Hero Smartphone Questions & Answers
It sounds from your description that the phone has a fault at the socket. Are you able to borrow or buy another battery to see if that cures the fault, and then you can be sure it is at the phone. If at the phone, you will need to see a service agent for the phone.
HTC Hero... | Answered on Jan 03, 2018
i gave my time to pokemon deluge and now what happend
HTC Hero... | Answered on Nov 21, 2017
your phone is lock so you have to go local store to open it
HTC Hero... | Answered on May 20, 2017
You can lock the screen of your HTC Hero screen with a draw pattern. Here's where to set the feature in the Android software.
1. From the Home screen, press Menu.
2. Tap Settings.
3. Tap Security.
4. Tap Set unlock pattern.
5. Read the info, then tap Next when ready.
6. See the pattern, then tap Next.
7. Draw the screen unlock pattern with your finger by connecting four or more dots in a row.
8. Tap Continue.
9. Draw the same pattern again.
10. Tap Confirm.
hope this helps
John
HTC Hero... | Answered on Jan 19, 2017
there is not itunes for the hero, itunes is an apple product. If you are wanting to play songs you downloaded from itunes on the hero, all you have to do is drag the songs onto the SD memory card under a folder called music.
HTC Hero... | Answered on Jan 10, 2017
Good Morning My Dear;First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
HTC Hero... | Answered on Dec 30, 2016
It sounds like your device may be paired with a Bluetooth headset. Try turning off bluetooth connectivity and see if that fixes the issue.
HTC Hero... | Answered on Dec 20, 2016
HI
Go for soft reset, select factory default setting in your mobile.
HTC Hero... | Answered on Nov 28, 2016
There are many apps can do this, but I always use LEO Privacy to block a certain number, it works and is very safe. Highly recommand it to you.
LEO Privacy Applock Hide Safe Android Apps on Google Play
HTC Hero... | Answered on Nov 24, 2016
What is Cache - How to Clear or Delete Cache
When is the last time you cleared your cache? Do you know what cache is? Do you know how to clear your cache? If the term cache eludes you, you're probably in good company. It's pronounced 'cash', yes, just like Johnny, and not 'cashay' as if you were from West Los Angeles.
Some of you may have a deep understanding for what cache is, and some may have heard it but wondered a little what it might be. Here are my thoughts on cache and what I feel is important to know about it, without getting all technical on you.
By the way, you can go about your lives never having to know the inner-workings of cache and be just fine. There are some things you might want to know though, like how to get rid of it! So read on if you want to know more about cache.
What is Cache?
In my own terms, cache is a temporary place to keep a copy of information for faster retrieval on the second request for said information. You might guess that I would continue on to say that information in this context is nearly anything you want it to be. It could be a stretch to say that moving the coffee brewer closer to you is no different than saving a web page onto your local computer so that the next time you need another cup, or need to visit that web page again, it's cached for quicker delivery.
And that's exactly it. Cache is nothing more than a mechanism that allows you to surf faster because the resources the page needs (images, the html page) are already available on the computer you are working on. The page doesn't need to reach out across the Internet to get that picture or other things.
Here's another way to think of it. Imagine you visit a particular site every day. This site has a banner graphic across the top that is quite large, and every time you visit, it takes a while for the large header image to travel across the wires every time. That sucks. Really, it does.
If that header graphic was stored on your computer, the browser you are using could be set up to detect that you've visited this page before, and that large graphic is sitting right over here next to us. Why bother to download it again when we have it right here!
Your browser can also be set up to detect when the graphic files are different and download the image to refresh your cache.
Most browsers are pre-configured to store some information into cache for quicker access to repeat data.
Why Clear or Delete the Cache?
Well, because sometimes you just get some wacky things happening. Many times while developing a web site I'll find that it's good to clear the cache every now and then to get a fresh perspective on the site. Once I clear the cache, I know that everything will be coming straight from the server in brand spanking new form and function.
Sometimes you just get to a point where things aren't acting like they should. Perhaps you start getting errors with some of the web sites you work on, where there probably shouldn't be an error. When this starts happening to me, the first thing I do is clear my browsers cache and restart the browser. If the same error happens again, then I know it isn't due to an outdated or corrupt copy of information in the cache. If clearing the cache rectifies the issue, good deal.
How to Clear or Delete your Cache
With the number of browsers floating around the world, and the number of versions, and also the number of blogs already demonstrating how to clear your cache, instead of regurgitating the information for you, here are a couple videos that should help you figure out how to clear your cache.
Most all browsers are set up with nearly the same menu systems and concepts, so the above videos should be good enough for anyone to figure out how to clear their cache in the browsers.
Understanding the simple concept of what cache is and how it's used by browsers to increase your surfing speed will help you in the future. No longer will someone say to you 'clear your cache' and leave you thinking they wanted to rob you, but walked off instead. No, cache is a good thing and helpful, but from time to time, things can go haywire and you'll need to delete your cache.
As always, if there are further questions please feel free to ask!
HTC Hero... | Answered on Oct 21, 2016
Your phone could just be slow for starters... too many widgets or apps can cause the phone to slow down. Also when you have loads of messages on your phone this makes the phone slow down when going into texting mode.
There are a few things you can try, First of all, go onto the marketplace and download an app called "task killer". Once downloaded this app will give you the ability to close any apps that are running in the background, using up your phones processing and so slowing your phone down.
You could also try deleting your messages and any unwanted apps. Download Uninstaller, from the marketplace for making quick work of that.
Last but for a last resort terms, Go into settings and click Factory reset, this does wipe everything off your phone so make sure you back up your little android. This will be sure to solve any problems or clear any viruses.
HTC Hero... | Answered on Oct 13, 2016
You can try Data recovery software!
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Watch this video and share it with your friends too so that they can also get their precious lost data back.
Facebook Homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Google+:https://plus.google.com/communities/109657948177651590858
HTC Hero... | Answered on Jul 19, 2016
there are many apps availble for navigation try to search in google play
HTC Hero... | Answered on Feb 27, 2016
I would just reset the tablet i asked they same ? but it never worked so i ended given up so just reset . When i tried other options it just made my tablet worse so i woud reset the tablet if that
HTC Hero... | Answered on Aug 09, 2015
942 questions posted
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
HTC Cell Phones
  • HTC Cell Phones
Most Popular Question
block
  • Cell Phones
