KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The beater won't come off of the mixer. cheri
Ned C Cook
Level 3:
President:
  • Master 3,433 Answers
  • Posted on Nov 07, 2009
Ned C Cook
Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1438445
Points
9966
Cheri;
I like the name. Anyway, pour a little wesson oil in the socket of the beater and wiggle it, then try again. Good Luck _Ned_
Can I get parts hot kitchen aid hand mixer model khm7twh beater won’t stay in because plastic tabs are broken that hold the beater in
Hello, Joe -
From a post on a YouTube video demonstrating a McGyver-type fix to a damaged beater ring (the plastic piece which holds a beater in place) apparently KitchenAid has discontinued the availability of the beather ring.
This is the link to the YouTube video with the McGyver-type repair demonstrated:
https://www.youtube.com/watch?v=CmS4FbROS50
The comment about the discontinued beater ring is from Dan Peters.
See the information here from KitchenAid:
http://producthelp.kitchenaid.com/Countertop_Appliances/Hand_Mixers/Hand_Mixer_Assembly_and_Operation/Beaters_fall_out
If you decide not to try the McGyver-type repair and choose to purchase a new hand mixer, you may wish to put the old mixer up for sale, to be used for repair parts (since it still has 1 good beater ring.) Or, you can send the old mixer to electronics recycling.
Best wishes.
Feb 27, 2018 • Food Mixers
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Mixer won't turn on after adjusting beater height
The kitchenaid warranty is exactly 365 days from date of registration "No Questions Asked" on day 366 you have no warranty and you gotta pay.
Now the good news; first check the wall socket, I know it works but check it anyway. then check your plug, did you step on it while you were working on the machine? The plug often falls to the floor during work and can get underfoot, you may have broken the plug it'self. next you will need a parts list for your model from Kitchenaid's website.
http://www.kitchenaid.com/customer-service/manuals/
My first suggestion is to try a minor adjustment of the speed control switch, they often get out of sync when you do something to the machine. You can find several videos of this on the youtube site. "Adjusting the speed control switch on kitchenaid mixer"
If the two or one of the top 2 screws on the speed control switch move it can shut the machine down just like an on/off switch. Did you remove the back cover during your adjustments? Did you remove and replace the carbon brushes on the side of the machine while working on the machine? If you did you might have put them back in incorrectly, if you did they will also act a a shutoff switch. If you did not take them out then DON"T as there are four ways to put the brushes back in and only one way is correct and there are two brushes to deal with. Has work ever been performed on the mixer before? Because if all you did was to adjjust the beater height screw then nothing should have effected the normal operation of the mixer. So if there is anything that you did but did not include in your description of work you performed then please let us know. We strive to give accurate solutions but... as I am a KA tech I do not have any other solutions with out the machine in front of me. Just so you know you can fix this yourself.
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
2answers
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
1helpful
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
5helpful
3answers
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
77helpful
4answers
Replacement Beaters for GE Hand Mixer
Hi, replacement beaters can be found at amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Ned
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
