Electrical Supplies Logo
Posted on Oct 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to change oil on my generator Pramac 16 hp vanguard S10000SVEP need a manual to read about my generator how much oil to use what type
Anonymous
Level 3:
  • Master 474 Answers
  • Posted on Oct 31, 2009
Anonymous
Master
Level 3:
Answers
474
Questions
Helped
190667
Points
1117
Brigsandstratton.com
2answers
We have a pramac genset equipped with a AC03 controller and time to time in AUTO mode it changes alone to MANUAL mode. Please, can anyone help? Best regards. FGaspar
You can changes to Auto mode.
Some generator has auto mode and manual mode. In generally, emergency generators have these two actions, when power grid is cut off, the generator will connect to machine automatically, then supply power to the machine.
If you need diesel generator set or more support, please visit at www.dieselgeneratortech.com
Why does my Vanguard 8000 generator pop the 40 amp breaker on the generator when I plug in the 30 amp cord into the generator .
There's either a short in the cord somewhere, or the breaker on the generator is faulty and needs replacing.
How to change oil in pramac gsw 50kw towable generator?
If you have a Yanmar engine...
There is a hose that is connected to the oil pan in place of the drain plug directly under the oil filter that will have an end cap. This hose is used to drain the oil into a waste container.
Download the service manual located at the address below and follow the instructions in the manual.
http://www.martindiesel.com/Documents/New%20TNV%20DIRECT%20Service.pdf
Hope this helps.
1helpful
Perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
Governor problem on 9 hp vanguard engine
Go online to Generac and they have parts list and owners manuals online. They will ship you parts.
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
