Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Play/Pause and Menu buttons simultaneously
until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to
repeat this step.
If the above steps did not work, try connecting iPod to a power
adapter and plug the power adapter into an electrical outlet, or connect
iPod to your computer. Make sure the computer is turned on and isn't
set to go to sleep.
If you are still unable to reset your iPod, use only one finger from
one hand to press the Center (Select) button, and one finger from the
other hand to press the Menu button.
On pressing the cord has to coil into the holder and if this wont happen there is some mechanical fault in the recoiler or spring.
You can pull the power cord once again outside and let it slide inside, repeat this sequence to allow the winder to respond and then it might pick up.
