Insert a text box either from the menu "Insert" --> "text box" or by clicking on the box "text box" (a small A is visible on this box) from drawing panel shown at the bottom of power point. You can type and move this box within the sheet.
Select the Text Box tool (looks like a black A) and click-drag to create a text box. Type inside the box. Use the handles at the corners of the box to resize it. You can also type in shapes that you create using the box, circle, and autoshape tools. Click on the shape to highlight it and begin typing.
Show All
Hide AllDo onehow do you type inside a microsoft powerpoint - default.aspx?assetid=za790050011033c="/uploads/images/default.aspx?assetid=za790050011033" alt="default.aspx?assetid=za790050011033" class="h_mi" />Add body or title text
Note If
your text exceeds the size of the placeholder, Microsoft PowerPoint
reduces the font size and line spahow do you type inside a microsoft powerpoint - default.aspx?assetid=za790050011033
make the text fit.
Add text to an AutoShape
Add text that wraps
Note To add text to a line, connector, or freeform (freeform: Any shape you draw by usinhow do you type inside a microsoft powerpoint - default.aspx?assetid=za790050011033, and Scribble tools. Freeform shapes can include straight lines and freehand curves. They can be drawn opened or closed and can be edited.) AutoShape, you must add text using a text box.
Add text to a text box
how do you type inside a microsoft powerpoint - default.aspx?assetid=za060447551033>Drawing
toolbar (toolbar: A bar with buttons and options that you how do you type inside a microsoft powerpoint - default.aspx?assetid=za790050011033ay a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Text Box
text box (text
box: A movable, resizable container for text or graphics. Use text
boxes to position several blocks of text on a page or to give text a
different orientation from other text in the document.), click, and then type or paste your text.
I hope this helps
Find links to information about saving presentations in the See Also section.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
