GE Profile WPRE6100G Top Load Washer Logo
Anonymous Posted on Oct 18, 2009
My GE washer (modelWBB4500E1WW) overflows about every 3rd or 4th load. It appears to overfill like it doesn't know the level of water. Even when set to small load it can overflow.
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Oct 18, 2009
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751654
Points
5690
Remove the front panel by using a putty knife to depress the retaining clips at the seam where it meets the washer top. (one on each side) Take the thin hose off the lower left side of the outer tub and clean it out. A short cut would be to cut off an inch and a half of it, but that's a one time fix, then the hose starts getting too short. To help prevent re-occourance, run a small hot load with a couple cups of bleach (no clothes) every few months. Make sure to rinse the tub on the largest level to prevent bleach damage to your next wash load.
Testimonial: "Thanks!"
Water level hose came off I don't know where it goes back
almost all washing machines works this way ,
look at this video it may help you ,
all kind of washing machines have those two connection !!
GE Washing Machine Repair Water Overfills Overflows Washer
1helpful
Not geting the cold water. Only once and a while even though set on Bright colors
Fixing a Washing Machine with Slow or No Cold Water Fill ...
? 7:40
www.youtube.com/watch?v=c5r49nuMjao
Feb 10, 2014 - Uploaded by SamuraiRepairman On washers with this problem that do the rinse cycle with coldwater only, the ... Top comments .... It's a front loading machine so I can't open it when it's on. .... GE Washing Machine Repair - Water Overfills, Overflows Washer ...
2answers
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1helpful
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
thank you for writing to fix ya.
Best Regards Richard
2helpful
GE wbsr1060T washer overflows on 'Super' load size setting
HI, there is a pressure switch for the water level regulation that seems to be malfunctioning in your unit at this time. You will need to replace this switch asap. this will correct this issue.
Click here to order
Occasionally it will overfill
The water level switch is your problem.
Open the control panel and remove the plastic hose from the level switch and blow through it.
Soap and dirt clog the bottom end and prevents the switch from stopping. The water continues to flow because of this blockage.
After you reattach the plastic hose , set the washer to spin and turn it on to reset the switch.
3helpful
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
1helpful
GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
2answers
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
