Epson Stylus C46 InkJet Printer Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The button that has a picture of a page and also a ink symbol is constantly flashing. there is enough ink and enough paper but it it constantly flashing and will not let me print a thing. please help.
Shawn O'Halloran
Level 2:
  • Expert 345 Answers
  • Posted on Oct 24, 2009
Shawn O'Halloran
Expert
Level 2:
Answers
345
Questions
0
Helped
97444
Points
966
If an Epson gets below a certain level in Ink for any cartridge, it will simply not print at all so if any of your cartridges are low, I suggest replacing them.
Hi how do i reset a epson 3650 all the lights are flashing thanks Pete
  1. Turn off the printer at the mains and disconnect the USB or Parallel data cable.
  2. Hold down both the ink and the paper buttons.
  3. Re-connect power and turn the printer back on (hopefully you have enough fingers/hands) while still holding down the buttons.
  4. As soon as the paper light flashes, release both the buttons then hold down the ink button for about 10 seconds and release.
  5. The printer should now be ok again.
When I turn on my epson nx110 a loud constant, buzzing noise comes from my printer. I have found that is based in the part that lifts up not the base of the printer. In addition the on/off button is...
you may need to software reset you epson printer, some epson printer has a print counter, once you have used your allowable print, it goes into errors mode, flashing the on/off button light..check also for jamb paper inside..
1helpful
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Paper problems
First thing you need to do Turn off the printer and Open the rear access door or cleanout area as we call that (back door) and clean all the rollers on the back. make sure also that you are using the deskjet paper and if you put 20 pages of paper on the paper tray make sure to fan it before you put it in. the alarming sounds or blinking on the printer indicates that the paper is jamming on the printer
-The ink is normal to move to center or left to right, But if you open the printer access door the ink or the printhead should stay on the middle for you to able to replace the ink cartridges and remove the printhead
3helpful
3answers
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
2answers
Printer 1270 front control panel lights are flashing constantly and the printer wont move or react to any manual inputs
Turn the printer off.
Press down the ink button and the paper button at the same time and turn the printer on (while keeping them pressed down)
After a second or two, the red paper light should start flashing.
Immediately release the buttons and press and hold the paper button again. Keep the paper button down for about ten seconds and release. After a second or two, the printer should go back to it's normal state.
Please try this and reply me for further doubts.
Regards, Nandini.
Ink issue
Normally if it's an ink cartridge problem, you will see there is a small cartridge symbol being shown in the right hand side window. If there isn't a cartidge symbol then it doesn't need a new cartridge. Normally when the red light flashes, it means there is some other problem such as paper jam or no paper! To change the cartridge, open the top of the printer, you'll see the cartridges on the right hand side, they should hopefully just pop out when you pull them GENTLY. To insert a new cartidge, follow the pictures shown and make sure you hear a 'click'.
I am not a techie at all so I hope this helps
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
1helpful
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
3answers
MFC-3240C
The printer may not be scratching your printout but you may have a clogged printhead. A clogged printhead will constantly miss a spot creating an effect of a scratch printout. Please run an all inks printhead cleaning routine (2 or 3 times) and create a test page. Best Regards
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
