20 Most Recent HP DeskJet 920c InkJet Printer Questions & Answers
Hp deskjet 920C print cartridges
After you wrestle with this for a week, dispose of the HP printer and buy either a Canon or Epson.
9/29/2017 2:31:57 AM • HP DeskJet 920c... • Answered on Sep 29, 2017
0answers
Service manual 920c hp
The Quick Help manual is located at http://h10032.www1.hp.com/ctg/Manual/bpd08798.pdf.
11/15/2016 1:12:31 PM • HP DeskJet 920c... • Answered on Nov 15, 2016
Windows 7 64 bit. HP Deskjet 920c will not load from HP program disc.32 bit. HP site says it no longer supports HP 920c. How do I obtain a 64 bit driver?
Unfortunately, if HP has ended support for a printer, there will be no new or updated drivers created for that printer to work with new versions of Windows. This also applies to Apple computers as well. You might want to visit this web site at HP.com for the 920c to follow the steps they list there: http://support.hp.com/us-en/product/hp-deskjet-920c-printer-series/28856/model/45443/document/c01796879/ As they mention, when a printer model is older, HP gives the driver code to Microsoft to embed in the Windows system, but that driver then is fixed in time and will get no more updates.
10/2/2016 9:52:39 PM • HP DeskJet 920c... • Answered on Oct 02, 2016
64 bit driver for windows 7
You could try a driver from a different HP inkjet printer that does have a 64 bit driver. But it maybe time to upgrade to a new printer.
9/25/2016 10:12:53 PM • HP DeskJet 920c... • Answered on Sep 25, 2016
Hp deskjet 920c. will not load to windows 7. 64 bit. it asks for the driver. It appears that I have a 32 bit disk and it requires a 64 bit driver. How do I obtain and download the correct driver?
HP have one of the best after sales services you can get , find the genning HP after sales service on line, enter your product number/model and problem ,its will search for your product and search for problem. then they give download of driver or other bits to be replaced at no cost, and they can or you can download a HP SUPPORT ASSISTANT or you can download first a HP support assistant but make sure it's a genning HP site good luck
9/22/2016 9:41:37 PM • HP DeskJet 920c... • Answered on Sep 22, 2016
Hp deskjet 5150 printer cartridge problem will not move with hp 5150
Hello, in order to help you need more info, recycled cartridges , or what?
11/29/2015 2:59:39 AM • HP DeskJet 920c... • Answered on Nov 29, 2015
0answers
Reset
Be the first to answer 8/7/2014 3:03:28 AM • HP DeskJet 920c... • Posted on Aug 07, 2014Be the first to answer
0answers
0answers
My HP DeskJet 920c prints pink instead of blue, new cartridge has been cleaned and blue is visible on swab.
Try running multiple "head cleanings" on it, or you might have the cartridge in the wrong location (if thats possible on that model). If not, then the interface board on the printhead may be faulty or the ribbon cable the sends the signal to the printhead assembly. Most of the InkJet printers made now days are considered disposable electronics by the manufactures. Due to the low price point and the lack of parts support or cost of labor to repair when they do stop working right. Good Luck
6/7/2012 9:32:29 PM • HP DeskJet 920c... • Answered on Jun 07, 2012
Disassemble hp 920c printer
This printer having inter locking system, you cannot find any screws for opening.You can observe there is gap adges of covers, inser tool/flat screw driver for opening the covers of left,right & top/back(both combined)you can observe right back side small power supply container.
2/2/2012 6:14:48 PM • HP DeskJet 920c... • Answered on Feb 02, 2012
Disassemble
This printer having inter locking system, you cannot find any screws for opening.You can observe there is gap adges of covers, inser tool/flat screw driver for opening the covers of left,right & top/back(both combined)you can observe right back side small power supply container, detach power out socket, take out, only one screw fitted at the center point of the power supply & its covered by specification stikker, find the screw, open it... check for component failure.. best of luck
2/2/2012 5:37:10 PM • HP DeskJet 920c... • Answered on Feb 02, 2012
What do the three lights on the top right of the 920c HP printer indicate?
Hi,The first light (from left to right) is the Print Cartridge Status.This will flash if one or more of the ink cartridges are low or the cartridge incorrectly inserted. Also flashes if the wrong type of cartridge inserted.If the ink is low the light will stop flashing when you open the top cover of the printer.The second light is the Resume Light.This will flsh when anaction isequired such s loading paper or clearing a paper jam.The third light is the Power light.This will flash green when the printer is printing.Hope this helps you. Thanks for using FixYa.
11/29/2011 1:32:06 AM • HP DeskJet 920c... • Answered on Nov 29, 2011
Hi I have just put in ink cartridges and the reg
Hello and Welcome to FixYa!Sir/Ma'am If the Check Print Cartridge message is shown and Red Light Flashing then it means that Either ink Cartridge is not installed properly or the function for detecting the ink level is disabled. For it Make sure that you install ink cartridges at correct position as indicated by the label on the print head holder. Press push mark until ink cartridge click into the place.If you are sure then you have installed ink cartridge properly then try following to stop the flashing of red Light.
  1. Lift the lid to the printer (cartridges are on the right side.)
  2. Turn the printer off, then power it on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts.
  4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct.)
  5. Take out the cartridges and close the top cover.
  6. Reconnect the power cord. The power and the resume lights (green and red) should be on.
  7. Open the top cover, reinstall the cartridges, and close the top cover.
Now Turn On the printer, Mostly this issue is resolved by this, But if still you get the message and red light still flash then surely its an issue of Ink Cartridge, your ink Cartridge is defective, You need to change the ink cartridge, Your problem will be solved.I hope this solution helps you.Don't hesitate to let me know if you still have some confusion in your mind.Please Rate my solution as "Maximum Stars" and then give your Words of Appreciation as a Feedback.Thank you Sir/Ma'am for taking my service and fir using FixYaConcerned: Muhammad Uzair Team : FixYa
11/5/2011 5:26:58 PM • HP DeskJet 920c... • Answered on Nov 05, 2011
HP DeskJet 920c InkJet Printer Logo
197 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
windows 7 64 bit hp deskjet 920c will
  • Office Equipment & Supplies
