I replaced the heater element & in the process of taking off the belt, the belt tensioner/bar poped back once I pulled off the belt. Now the tensioner/bar does not have enough tension to keep the belt tight. Please help...
Check closely where the idler bracket was at and also the spring location.
You look for a worn area on the frame of the dryer and also the worn area on the idler arm bracket. Once you locate the right place for them to go, then put your spring on and check to see where it may hook up, there should be a small worn spot to look for...Just remember that the spring will be under tension when it is hooked up. So look for an area that would be worn with the spring stretched out somewhat.
I will send you a website to check also, they have schematics of dryers and they may be able to show you the approximate location of the bracket.
http://www.partselect.com/ or try this one...
http://www.appliancepartspros.com/index.aspx
Good Luck,
I hope this helps.
Open the hood. Disconnect the negative (black) battery cable.
Inspect the fan shroud for the accessory belt routing diagram. If the diagram is missing or illegible, use a pen and paper to draw your own diagram before removing the belt. The new belt must be routed around the pulleys exactly as the old one was.
Locate the spring loaded belt tensioner on the front of the engine. There is a small pulley attached to the bottom of the tensioner arm.
Slide the square end of the breaker bar into the square hole in front of the tensioner pulley. Rotate the breaker bar counterclockwise and the entire tensioner will move enough to relieve the tension from the belt. Pull the belt out from under the pulley and slowly let the breaker bar retract.
Remove the accessory belt from each pulley with your hands. Rotate one of the fan blades to the top side of the engine with your hand and pull the belt around it. Repeat this process until the belt is around all of the fan blades. Pull the belt out of the engine compartment.
Route the new belt carefully around each fan blade. Wrap the belt around the crankshaft pulley to begin the belt routing process. Refer back to the belt routing diagram instructions to properly route the new belt around the accessory pulleys.
Turn the tensioner counterclockwise again with the breaker bar. Position the new belt evenly under the tensioner pulley. Allow the tensioner pulley to tighten against the belt. Pull the breaker bar out of the tensioner.
Reconnect the negative battery cable.
Start the engine for five to ten seconds to seat the new belt. Turn the engine off. Visually check that the belt is properly seated around all pulleys.
