Sylvania LD320SSX LCD TV Logo
Posted on Oct 06, 2009
Sylvania ld320ssx remote code for att uverse
Att uverse remote will not work with this tv. tried to scroll all code and keyed all suggested codes.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
5272
Points
21
Try 1864. It worked for a Media-Com remote, when none of the other codes worked.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Sep 19, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
3835
Points
2helpful
2answers
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
1helpful
2answers
I need code for att uverse remote for sylvania lc195slx tv
Sylvania Television 1004, 1007, 1018, 1027, 1153, 1056, 1057, 1059, 1060, 1124, 1150, 1145, 1279, 1296, 1387
Also try these. These are codes that may work with that type of tv with the att remote.
3answers
Remote code for att uverse to sylvania lc320slx lcd tv
Try all Funai codes too, starting from the last in the list.
1helpful
Comcast universal remote control does not have setup code
Try 1864. It worked on my Media-Com remote when none of the other codes worked
2answers
Need code for sylvania lc195slx
hi! i have a couple of codes here for your sylvania tv just try them 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161 hope it would help! goodluck!!!!
Need code for a remote
hi! i have a couple of codes here for your sylvania tv, just try them hope it would work! goodluck! 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
3helpful
2answers
32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
