20 Most Recent
Toymax Viore 42 in. Plasma TV Questions & Answers
Hi , was watching my 42 inch VIORE Plasma TV last
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
Model#pdp42v18ha power on black screen indicator light works cuts off in 5 seconds
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
