Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse 32" HDTV picture stopped working
I have a westinghouse 32" tv and started smelling a burning smell. Then heard a pop and the picture went out. I've read on this website that it could be a defective transformer so i checked and sure enough it is. Is this a part that I can replace or is the tv trash now?
    New Friend:
  • 92 Answers
You can replace the power supply. Look on www.shopjimmy.com or www.discount-merchant.com for the part.
Posted on Mar 26, 2010
SOURCE:
My tv smelled like plastic was burning and then the screen all of a sudden went black but i could still hear the audio.
Your backlight inverter board has failed. This may be due to a bad capacitor which is easy to repair, or the inverter transformer may have burned out, in which case it may be replaceable or the complete inverter board will need to be replaced.
Feb 14, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
As it has become clear, there is a problem with Westinghouse SK-32H540S , burning or chemical smell. Is this an easy repair or total wash ?
What is the problems of the response of the tv?Tv power LED light indication flashes or totally dead?Or something else problems?If it is the tv power problems.The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Westinghouse 32" Flat Panel LCD HDTV
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
May 31, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television I have a 32" tv Westinghouse, it was on went I hear a sharp pop like glass breaking, I unplug it for a willy plug it back in and nothing happen what...
Ur power supply board is dead.Take ur tv aparts,replaced the power supply board.Ur tv will get ur power back an the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My tv picture went out and started smelling now it doesn't come on and when i plug it in it smells
smell? maybe something had burn out inside. or something got to hot.
you can start doing the diagnostic, but let it rest a bit.
then, try it again.
if nothing, you will have to disassemble it and check for fuses in the power card to begin.
Apr 27, 2010 | Westinghouse LTV-27w6 27 in. LCD HDTV
32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Oct 23, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse TV no picture just sound. 32
one or 2 caps in the power supply they will be domed from venting
Sep 16, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Burning plastic smell westinghouse hdtv
The problem may cause by the defective transformer on Power supply board. there are 3 transformers on the power supply. http://www.lcdparts.net/LIPSInverterDetail.aspx?InverterOriginal=4H.B0700.051
Please do the vision inspection on power supply, you should be able see the obvious burn on one of these three big transformers.
May 11, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
MAGNAVOX TV BURNING SMELL TV WENT POP AND WENT OFF
Well that pop had something to do with the power components inside the TV frying. I would have to say there is nothing you can do to repair it as its dangerous to work on such things.
I wouln't waste my time bringing it to a repair shop they will probably tell you to just buy a new one.
Jan 05, 2009 | LG RU-27FB30C TV
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
331 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
