20 Most Recent Sony KV-32S45 32" TV Questions & Answers
Why apex LE4643T television will not turn on?
Power supply regulator section circuit fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
6/25/2014 4:21:04 AM • Sony KV-32S45... • Answered on Jun 25, 2014
2answers
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
6/5/2014 7:52:42 PM • Sony KV-32S45... • Answered on Jun 05, 2014
No power after storm
You will need to replace it. The storm fried your board for sure, there is no fix for that, and a broken board is useless. you can't really put it back together because the entire surface of an electornics board is conducting electricity through it from component to component. If it could be fixed, it will surely cost you more to fix than buy a new one. Sorry to be the bad news bearer but it is shot, you are left with a giant paperweight.
9/28/2012 6:02:00 PM • Sony KV-32S45... • Answered on Sep 28, 2012
Only a snowy picture, not reading cable signal.
Check and replace its tuner.
8/29/2012 8:33:34 AM • Sony KV-32S45... • Answered on Aug 29, 2012
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
7/23/2012 11:25:58 AM • Sony KV-32S45... • Answered on Jul 23, 2012
Sony vega 4-086-880 program source stays on screen. How to remove?
Use the "display" button on the Sony remote to remove it.
4/18/2012 2:24:47 PM • Sony KV-32S45... • Answered on Apr 18, 2012
Kv-35s42
HI
Don't beat it with a bat LOL, the problem your having is a simple solution, however this would be best left to a qualified tech to do, the Screen Voltage needs to be tweaked up just a tick, I've worked on alot of these sony's and 9 times out of ten thats what it is.
Mark
4/4/2012 8:23:45 PM • Sony KV-32S45... • Answered on Apr 04, 2012
The pilot lamp blink many
The blinking Standby light is an indication of a blown Line Out Put stage. It can be either a blown horizontal output transistor or the Flyback transformer. Either way you will need professional help to replace them. The access to these components on an old TV is a little tricky esp: considering the weight of the TV.
6/2/2011 9:34:10 AM • Sony KV-32S45... • Answered on Jun 02, 2011
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
3/6/2011 1:48:46 AM • Sony KV-32S45... • Answered on Mar 06, 2011
No picture, stand by timer led is flashing
check r607 & ic601
2/5/2011 3:22:13 AM • Sony KV-32S45... • Answered on Feb 05, 2011
My KV32S45 model tv has clear sound but no
your tv has a flyback problem it is a old model..my advice instead of investing to repair it buy a new tv.
7/11/2010 3:15:00 AM • Sony KV-32S45... • Answered on Jul 11, 2010
Y dont now the flyback number, chassis aa-2d
1-453-207-11
is the sony part number per Encompass parts.
5/22/2010 7:45:31 PM • Sony KV-32S45... • Answered on May 22, 2010
I can't get any power? What is wrong?
Hello cwcritters, hi, does your tv front panel has any pilot light on or nay sign that the TV is on, if yes, there is problem with the main board and power supply, probably a short, this TV is on standby, here are the things to check, a shorted horizontal output transistor, a bad voltage regulator, or any ICs that are overheating, NOW if there is no light at all, then your TV may have fuse open. A fuse opens when a user plugs the TV while the power switch is on, causing a surge of electric current. or TV develops a shorted regulator. If you dont know anything about electronics, dont do the service yourself, you may further damage the TV, better call service.
5/15/2010 1:32:46 AM • Sony KV-32S45... • Answered on May 15, 2010
Tv keeps blinking model35s42
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
4/15/2010 6:22:28 PM • Sony KV-32S45... • Answered on Apr 15, 2010
My aunt who has an KDL26U2000 sony tv and has it
Check the manual. See whether volume lock menu is there!
Then lock to the desired value & keep the volume lock in ON position.
Hope she does not know to re- set it!!
3/30/2010 7:34:39 AM • Sony KV-32S45... • Answered on Mar 30, 2010
PIP on and we want it off
Get a new remote control from www.remotecontrols.com. You can't turn off PIP any other way.
1/24/2010 2:23:32 AM • Sony KV-32S45... • Answered on Jan 24, 2010
I'm just trying to get a price estimate for a high
estimate price is $ 81.00 to $100.00 ,thats for the FLYBACK part only, AJ
11/11/2009 2:24:26 PM • Sony KV-32S45... • Answered on Nov 11, 2009
TV shut off Red light blinks 9 times
yes the power board and possibly both the sustain boards are compromised. Not a DIY without knowledge tools and unjderstanding electronics.
Call a professional you will find in the long run it will be chesaper than trying to DIY and ending up spending 2 times the cost because you did not do it right. It is not just a matter of changing boards like some indicate It requires tuning and circuit diagrams and an ability to check voltage and know why that reading is being displayed
9/22/2009 11:10:16 PM • Sony KV-32S45... • Answered on Sep 22, 2009
How do you install closed captions
Press the Display button on the remote several times until Caption Vision appears. See page 16 of this manual for info about Caption Vision: http://www.docs.sony.com/release/KV32S40.pdf
See page 20+ for info about Setup menu and Caption vision menu.
9/16/2009 2:15:47 AM • Sony KV-32S45... • Answered on Sep 16, 2009
Sony KV-32S45 32" TV Logo
66 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
apex le4643t television will not turn
  • Televison & Video
