20 Most Recent Westinghouse LTV-27w7 7 in. LCD HDTV Questions & Answers
No picture - audio ok. Power cycled (unplugged for 30 seconds) but didn't resolve. Picture comes on when powered on, disappears after a second.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
5/24/2016 6:50:00 PM • Westinghouse... • Answered on May 24, 2016
Need a screen for 50 inch screen
You have a 27 " tv.
4/21/2014 11:26:55 PM • Westinghouse... • Answered on Apr 21, 2014
11answers
Westinghouse lcd tv parts
HAVE A WESTINGHOUSE LTV32-6HD. HAS SOUND, NO PICTURE. APPROXIMATELY 8 MONTHS OLD
8/9/2013 7:15:07 PM • Westinghouse... • Answered on Aug 09, 2013
Can I connect headphones to the TV?
Only if you have an external headphone amplifier that is connectedto the TV audio out.
9/23/2012 11:58:24 AM • Westinghouse... • Answered on Sep 23, 2012
3 channels missing
Those channels all are related in the same tuning band that most tuners have----suspect you have a bad tuner--unless you are using a box in which case suspect the box is the issue.If the tuner is the problem there are ways around that--used a cable box set to the rear inputs (audio/video) on your set and bypass the problem.
6/4/2012 1:59:57 AM • Westinghouse... • Answered on Jun 04, 2012
Hi, my tv only comes in on 480 not 1080p called the cable company an they said it's on the tv end. how do i fix this.
Sounds like a hookup issue--what is being used for 1080 on the set?HDMI? Component?
4/23/2012 3:42:17 PM • Westinghouse... • Answered on Apr 23, 2012
I need speakers for my Westinghouse LCD tv, Model
Try ebay
9/26/2011 9:49:45 PM • Westinghouse... • Answered on Sep 26, 2011
2answers
My tv turns on, but gets no picture. It
Hello The problem of your television is no picture.Usually in that symptom of LCD TV the problem is no back light.If there is no back lights the screen or display is totaly black.The problem is in the back light driver board, maybe there's a blown mounted fuse in the driver board or bad or leak capacitor from the supply of the back light driver board.Thanks...Hope it will help you to fix it..
9/3/2011 11:33:28 PM • Westinghouse... • Answered on Sep 03, 2011
For some reason, the TV
You have problem with your power supply, power cord and if you are technically know how you may inspect the power supply if fuse blown. If Black color you have problem on the power supply this is for serviceman only, if slight clear and you set a cut you may try to replace it.
8/15/2011 6:57:15 AM • Westinghouse... • Answered on Aug 15, 2011
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
137 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
no picture audio ok power cycled
  • Televison & Video
