You can find remote control codes for your TV here. Select your exact model number. If the codes listed don't work, there is a listing of compatible brand codes that you can try.
if you check with multimeter, you know all worked fine, you need code programing of the tv, this code is for reconfiguring your tv, search by model, by device and brand, oh you need the remote control original, for solve this problem...
because the problem is programing electronic, the tv have a cpu and have a program, who can solve is expert electronic....
Most universal remote controls have a scan feature to find a code where one is not available. If this process doesn't work, additional assistance may be found at Community.InsigniaProducts.com.
Insignia TVs are basically re-branded major brands made for BestBuy. I would try codes from the following TV brands:
LG Philips Magnovox RCA Westinghouse Polaroid
The codes from one of those should work. Also depending on which universal remote you are trying to use, there may be a scan feature on the remote itself that searches all frequencies for the appropriate one for your TV, so I would look into that. Hope that helps and good luck!
ns-lcd26a
Hi,I fixed my here's issues i had and the fix i did..
ns-lcd26a
Every now and then i would get snow and a pink picture.
Then tv stop turning on .
To fix i seen on main board capacitor cp25 and cp28 near the heat sink was bad
They were both 470uf 35v...
on the power board i seen c531 47uf 50v was bad.
i also heated up the heat sink on the main board to resit the chip ,,
and tv now works
I didnt bother putting the huge shield back on main board i figure it was a issue to over heating the cpu instead take the hit to the brain from the fcc radio wave lol
First do the 3 caps and see if it works if not then do the blow dryer to the heat sink on main board
