20 Most Recent
Universal Remote Control DIRECTV Universal Remote Control Questions & Answers
DirecTV remote won't work with my new RCA TV
yes go into kitchen open bin drop in these remotes are not meant for our tv/dvd/sat etc they are for a chinese system save your hair chuck it away sorry to say I got one of these oh dear !!!!!!!! you would be better getting a sky type copy remote from the two pound shop I did works great
RC64 remote will not work with my RCA surround sound RT2580
I hate to say it's unlikely that a "Universal" remote from DirectTV has compatibility with every system and manufacturer. However, my directTV model remote (and there are numerous ones) has a search function with which you don't need to enter a code... it finds one for you. If the control documentation doesn't mention such an option (Code Find), then I'd say your SOL. I'd recommend a Universal Remote made for no specific purpose but to be a UR... using a system included UR never comes off very well.
Magnovox: model 37MF337B/37
There arethree possibilities that cause this symptom.
1. The buttons on the TV are shorted and must be replaced.
2. The firmware must be upgraded.
3.The main bd is bad and must be replaced.
Need direct tv code for supratech tv towork with any remot control
Replacement remotes should come with the codes, the las 1 I got had a booklet of codes for various types and makes of device, some had several codes any you needed to try each in turn until you go to the correct code. Not sure if the different makes of remote need the same or differnt codes. I suggest you contact the remotes maker for the possible codes.
Need instructions on how to program a ONE FOR ALL
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window" to get gathered related posts. .
Is there a code for my directv remote that will
The following code is the most popular for your brand.
00724
Setup Instructions
Set the "Mode Switch" to Device 0.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the 5 digit Code above.
Try your new code and tell us how it worked!
Cannot program Dish Universal Remote for Emerson TV
This worked for me. I had to scan down quite a few times but eventually my tv turned off and I set the code with the # button. It may work for you too and save you some money on a UR.
http://www.satellite-tv-planet.com/DishNetworkRemoteControlProgramming.htm
Scan For Device Codes
If the code for the device you are programming is not listed in the
user manual or on this site, try these steps to scan the remote
controls memory for device codes.
1) Turn the power on the device on
2)
Select and hold the mode button for which you are programming, such as
the TV button, on the remote until you see all the lights of the mode
buttons flash. Once you let go, that mode button that you chose should
now be blinking. When using the Aux mode button only use the number pad
to enter 0 for a second TV, 1 for a second VCR/DVD, 2 for a amplifier,
tuner, or cable box. Then press the STAR (*) button.
3) Press the power button on the Dish Network remote control.
4)
Repeatedly press the UP or DOWN button on the remote to scan for the
correct code (do this slowly so you do not skip over the right code for
your device). When the correct code is reached the device will turn off.
5) Press the POUND (#) button to store the code in the Dish Network remote.
6) Press the power button to turn the device back on and try using other buttons on the remote to make sure that they also work.
Sometimes the power button will work while others may not.
