The Pioneer sx-316-5 has a protect mode.if it will not power on from the power stand by button and you tried un plugging the unit for 60 seconds then try this-with the unit plugged in and in stand by mode push the enter and advanced surround buttons at the same time for 2 seconds-you may get power back if your unit was in the protect mode.check all of your connections first to make certin that there is not a disconnected wire or connecter.
Check the resistance of the primary on the main power transformer, (with power off) should be 1-3 ohms. If open you need a new transformer.
If good turn it on and check for ac voltage (120v) there.
I get 120AC to the main relay but no voltage on the low side,main relay is not clicking in.
No power going into the primary side of the main transformer.
This radio is about 4-5 years old looks new from inside and out, I used it everyday with the TV, but never ran maxed out,,,, mostly at about 30-50% volume.
