Error message 0x610000f6 on an HP C309A series printer. Tells me to restart and either the error message returns on restart or the printer hangs on shutdown and has to be restarted at the power supply.
>try to do hardware reset
>while printer is on unplug power cord at the back of it, press and hold # and 6 buttons on your printer, while holding the buttons plug back power cord, printer should initialise you can release the buttons after 10 secs or until you see semi full reset on the display, if the printer will not automatically turn back on press the power button, if it ask for you to set the region and laguage again then you have done the reset successfully
>this hardware reset should clear the error otherwise better contact hp
