Refrigerators Logo
Posted on Sep 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have water standing below the veg. trays, not sure where it is coming. How do I find the drain lines.
Anonymous
Level 3:
  • Master 832 Answers
  • Posted on Sep 25, 2009
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
307721
Points
2315
The water comes from the accumulated moisture. Just
clean the drain at the back of the veg tray. Get you veg. tray out so you will find the drain.
Anonymous
Level 2:
  • Expert 193 Answers
  • Posted on Sep 29, 2009
Anonymous
Expert
Level 2:
Answers
193
Questions
0
Helped
75321
Points
384
The water is from the defrost cycle. A small drain under veg trays. Make certain that they are not blocked
3 Related Answers
Anonymous
  • Posted on Jul 11, 2009
SOURCE: I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Anonymous
  • 1606 Answers
  • Posted on Aug 02, 2009
SOURCE: GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Anonymous
  • 33 Answers
  • Posted on Aug 26, 2009
SOURCE: Kenmore Refrigerator #1068658281, top freezer.
sounds like drain is clogged. does water collect in drain pan near compressor?
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also...
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
Getting water in veg bins
Are the veg trays right under the drain hole? Check the hole is clear!
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
My maytag refrig. has water laying on bottom under the veg. drawe
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
3helpful
Water gathering at bottom of fridge.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
2answers
Model Number TBXW25FP Refrigerator has large volume 1/2 water accumlating inside on the bottom under the Veg and Fruit Trays, unable to locate any source. Need to sponge out every two days. What are...
your freezer drain is plugged and water is dripping into frig you need to get fixed and soon or it will freeze air openings to your frig and stop cooling
GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW VEG. BINS, HEAVY CONDENSATION ON WALLS OF REFRIG. CANT FIND A DRAIN HOLE AT BASE OF FREEZER OR FRIG.
Water-on-bottom-of-veg-bens -cleaned-tube-drain-but=still-same-water-still-goes--to-bottom-of-veg-bens. donald-clemente.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
