20 Most Recent Amana ATB2135HR Top Freezer Refrigerator Questions & Answers
How to get my Amana fridge to stop leaking water from the freezer to the refridgerator?
These Amanda units appear prone to this problem. The fix is use of a drain kit. Your drainage spout is freezing over. The regular spillage is related to the defrost cycle of the fridge. Here is a page listing the kit: Refrigerator Parts
12/9/2017 11:32:26 AM • Amana ATB2135HR... • Answered on Dec 09, 2017
2answers
Am I supposed to use a regular 40 watt appliance
Yes, the 40 watt standard appliance bulb is the correct choice.
11/1/2013 1:24:20 AM • Amana ATB2135HR... • Answered on Nov 01, 2013
0answers
Can not find out how to get cover off of the light bulb
Here you go hope this helps http://www.amana.com/content.jsp?pageName=HT-RF-FreshPerf-11
2/16/2013 11:00:28 PM • Amana ATB2135HR... • Answered on Feb 16, 2013
Getting water in veg bins
Are the veg trays right under the drain hole? Check the hole is clear!
4/23/2012 8:51:19 PM • Amana ATB2135HR... • Answered on Apr 23, 2012
Freezer frosting
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/22/2011 12:01:55 AM • Amana ATB2135HR... • Answered on Sep 22, 2011
The freezer has stopped freezing. The
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
7/27/2011 10:58:32 PM • Amana ATB2135HR... • Answered on Jul 27, 2011
Hi, I have an Amana refriderator
Take the back off the fridge and there is a fan that should be working transferring cold air to the fridge, see if this is working if not then it needs replaced. Also check for any frozen coils and othe air obstructions and looks like you already done this so check the fan.
3/13/2011 3:12:02 PM • Amana ATB2135HR... • Answered on Mar 13, 2011
Our Top Freezer Refrigerator, Amana, doesn't seem
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3/1/2011 1:08:13 PM • Amana ATB2135HR... • Answered on Mar 01, 2011
My ice maker will not fill with water. I can't
Water valve is faulty dripping and causing line to freeze, replace the water valve and defrost line .
2/14/2011 3:57:01 PM • Amana ATB2135HR... • Answered on Feb 14, 2011
Amana ATB2135HR Top Freezer Refrigerator Logo
68 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
refrigerator runs almost constantly
  • Refrigerators
