It could be the motor, but don't rule out the switch. If there is a small plastic tube that exits the back of the pump/motor, there is a switch attached to this tube. The switch is avaliable online and can be installed after removing the pump from under the tub so that there is room to work on it. To check the pump, remove the switch and tape the two wires together, quickly plug the pump in and them unplug it to see if the pump comes on. Do not run the pump for more than a second or two as pump seal damage may result.
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: [email protected]
Rod Kidman
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
