Drain stoped up. Take off the bottom panel up top drain is in middle at back. remove the ise with hair dryer. air is the best to use to unstop.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
