Dryers Logo
C
Craig Newhouse Posted on Oct 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u install right side venting for kenmore dryer 81383
Jim Hicks
Level 3:
Master:
  • Master 661 Answers
  • Posted on Oct 30, 2019
Jim Hicks
Master
Level 3:
Master:
Answers
661
Questions
0
Helped
205825
Points
1952
5 Related Answers
Anonymous
  • Posted on Jan 11, 2008
SOURCE: Vent Kenmore HE2 dryer from the Side, not the back
I'm in the same boat as you. Just had my dryer delivered today. Did you find a solution?
onthejob5130
onthethejob1
  • 640 Answers
  • Posted on Jan 18, 2009
SOURCE: How do you change the dryer vent on a Kenmore 800 series
yes and here is the part kit that you need..part # 279818..onthejob..everthing you need is in this kit..it all comes together..
Anonymous
  • 760 Answers
  • Posted on Jul 20, 2010
SOURCE: Install side vent for GE dryer
Unlike some other dryers that have knockouts on the side and allows the vent to come out the side I don't believe this one does. The air duct has the rear discharge outlet built right into it. Since it sounds like you don't have enough room to put a 90 degree elbow on the back of the machine, which would move the dryer out about 6 in, you might try one of those square duct dryer fittings. See link for example:
http://www.northlineexpress.com/itemdesc.asp?ic=5CO-89638&source=froogle&kw=5CO-89638. If you had to you could put this 90 degrees, and continue it out with retangular metal duct.
John Riley
  • 441 Answers
  • Posted on Nov 09, 2010
SOURCE: How do you side vent the Kenmore 800 dryer? I
You will need to take the dryer apart, pull the drum out. Then at the bottom you will see the main discharge, take it off and insert a 45 degree elbow, you will need to then install hard venting to reach the knock out on the side. Be sure to use metal duct tape when sealing the venting to avaoid fire haz.
Anonymous
  • Posted on Jan 14, 2011
SOURCE: Right side venting for Samsung dryer DV448AE
Hi, You can see it on this link.
http://www.samsung.com/us/appliances/washers-dryers-accessories/DV-1A/XAA
We have a long dryer line to the out side vent... how do we improve drying time... line is clear and we clean the lent from the dryer frequently...also, clean lent after every use..
If you may want to look into installing a booster fan for your vent line.
It can really help in cases such as yours when the vent line is extra long.
How do I change the dryer vent from rear to side
there is usually a pc that can be removed on the side a round plate with light soder
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
2helpful
2answers
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
1helpful
How do you side vent the Kenmore 800 dryer? I cannot rear vent the dryer due to space limitations. I MUST side vent.
1helpful
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to www.sears.com and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
3helpful
2answers
I need the installation Instructions for a Kenmore 500 Dryer
While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
Dryer installation
whether it is a plastic vent or an aluminum vent hose - you don't need to worry about heat. you do have a problem if it is really, really bent at an angle. the overall inside diameter is substantially reduced. lint that comes out of the dryer will catch at the ninety angle and clog. how obtrusive would it be if you maintain a four inch clearance at the rear of the dryer?
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
