20 Most Recent Kenmore Elite Oasis 6808 Electric Dryer Questions & Answers
I have a Sears Kenmore Elite Oasis Model # 110-67087600 . When you push the start button it shows the time and then a few seconds later something clicks and the letter F starts flashing . The time and
You said that it flashes F and the time, that is not the time, that is the rest of the error code and I need to know what number it is.
1/1/2018 10:57:32 PM • Kenmore Elite... • Answered on Jan 01, 2018
Elite Oasis. What does the F-40 code mean?
F-40 is a communication error between the main board and the motor control unit, or it could be a bad inline fuse between the two in the wire harness on the l-1 side.
10/24/2015 4:21:12 PM • Kenmore Elite... • Answered on Oct 24, 2015
My kenmore elite quietpak 9 dryer blows air but does not get hot, how do I fix it?
ELECTRIC Dryer no heat or little heat, or shuts down to fast: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity. A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats. Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
4/13/2015 5:55:45 PM • Kenmore Elite... • Answered on Apr 13, 2015
How to troubleshoot a kenmore elite model 110 timer works but dryer isnt coming on
check door switch, the push start button and the thermal shut off fuse
3/30/2015 11:32:34 PM • Kenmore Elite... • Answered on Mar 30, 2015
2answers
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
9/9/2014 1:03:51 AM • Kenmore Elite... • Answered on Sep 09, 2014
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
9/5/2014 4:38:41 AM • Kenmore Elite... • Answered on Sep 05, 2014
How do I replace the thermal fuse?
Check these instructions out. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/1-6-917283-/Kenmore-Dryer-won-t-start-11067032601 The thermal fuse is located in the vent duct.
9/2/2014 2:00:46 PM • Kenmore Elite... • Answered on Sep 02, 2014
0answers
Sears repair
Be the first to answer 8/22/2014 12:24:19 PM • Kenmore Elite... • Posted on Aug 22, 2014Be the first to answer
Burning smell in dryer
Have you checked the motor? Plenty of lint and dust gets indie it. If you can remove if and use compressed air to blow it out. Also don't overlook the fact all the spade connectors will also collect lots of lint and dust which is quite flammable. Also check the tensioner and guide wheel they get pretty dirty and when they heat up the lint can start buring.
8/11/2014 7:07:28 PM • Kenmore Elite... • Answered on Aug 11, 2014
Where is the thermistor located on model # 110.67032601
I couldn't find it either on the Sears diagram even with a search. What makes you think it is the thermistor? If you have a no heat problem it is probably not. If the dyer runs but not heat first keep it simple make sure there is 240 VAC at the outlet. If you have one bad fuse or a bad circuit breaker it can cause a no heat situation. There are many components that can cause a no heat situation if that is what you have. I need more information to help you.
8/7/2014 1:32:39 AM • Kenmore Elite... • Answered on Aug 07, 2014
Am mouse died where i cannot reach how can i get did of the smell
If you can you get to it enough, pour lime on it.
5/21/2014 1:26:58 PM • Kenmore Elite... • Answered on May 21, 2014
F1 code on model# 110.77042600
My amana touch pad started going wacko...beeping constantly....then a F1 message....i unplugged it over night....then it worked for about 2 more days with no problems..then the next day it acted up again...Then i unplugged it again( touch pad only) over night . It has now been 1 month and no problems with it....so maybe before you dish out $$$$...maybe this will work for you also
4/27/2014 1:31:11 PM • Kenmore Elite... • Answered on Apr 27, 2014
Kenmore elite oasis st model #110.68062801 won't run.
First check the breaker. You may have one leg out. Then check the starter switch. Also check the door switch. It could be broken or mislodged. When it is fully engaged, it will start up. Lastly the motor could be burned out. If it is an older model, then consider a new one. However, the repair on this is not that high if you can do it yourself.
4/27/2014 2:45:33 AM • Kenmore Elite... • Answered on Apr 27, 2014
0answers
Kenmore Elite Oasis 6808 Electric Dryer Logo
136 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
replace thermal fuse
  • Dryers
