Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Testimonial: "Thanx alot. Will try it out with our new fax."
Sounds good. I will try it out. Thank you
