20 Most Recent
HP 640 Inkjet Fax Machine Questions & Answers
I'm not receiving certain faxes. How do I ensure they will all be sent to me?
Dear
Pl. check the memory received., If your fax setting is not done for memory setting i.e. when you receive a fax that immediately printed .Then the fax machine is right some times voice calls also generated if it was given earlier for that or used for voice call, so caller may try to communicate for voice call and got the fax tone (as the fax machine is in auto mode),he simple disconnect the line.
and fax machine may display some error message.
Thanks.
My HP 640 will not print. Ran the test, no print.
If these are new cartridges, make sure you removed all of the protective plastic wrap that comes when packaged. usually its red , yellow or orange plastic tab that should be removed.
If these are not new cartridges, you may need to try another set.
Try running the head cleaning utility under the printer utilities options
HP is very good at having this utility available to trouble shoot most common problems. If you don't have this utility, try updating your printer driver. (basically uninstall the printer and download the driver from the HP website, and reinstall the printer using the latest driver).
Hope this helps..
~enov8
Why my HP 640 Fax will not receive a fax?
Your firstly need to put your hp fax machine through the machines fax diagnostics found under the tools menu. This will hopefully identify any obvious problems.
You need to ensure that you have the correct cable from your telephone socket to the fax machine. It should be a BT Plug to RJ11 Crossover telephone cable in the U.K. This cable reverses the polarity of the terminals and will look identical to other terminals but is not.
Available from cabling for less Item Code BT-203X Price 3.28 plus vat and postage.
Ask your telephone line provider to check there is no noise in the background as fax machines sender and fax machiine receiver are like birds in love. They sing to each other before the receiving machine recognises the sending machine and accepts the message.
If you require any further assistance then please do not hesitate to contact me.
HP 640 fax won't send fax but phone works
Unfortunately wer purchased two new hp office jet 7610 which do not come with cabling and we could not get the fax to work. I spent 3 days on the telephone with hp and British Telecom each of which blamed it on each other. After doing some research on the internet I discovered that hp require a strange cable formant which is called a 'cross-over cable' is required. I bought them from cabling4less.co.uk and the product code is BT-203X. They can be found on their web site
www.cabling4less.co.uk The link is:
http://www.cabling4less.co.uk/category.php?cat_id=237 This should resolve this frustrating problem.
Printing
this printer carrege unit is short please replace the printer carreage unit
How can i access old sent reports?
You will need to press menu repeatedly until reports appears. Then use the left and right arrow keys to find the sent journal. Then press ok. It will should print the last 40 faxes.
HP640 - says paper jam, reset and returns to
Hello T
There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
When I receive a fax it comed back blurred
Check print out from system, if its good printer is good, you can suspect other side fax machine..Generally most of the fax machines are "Thermal Technology" black & white scaled machines, this technology is old, we can't expect that much quality print outs..
My conformation sheet coming back blank
I bet you a 'copy', or received faxes would be the same, and it would have been very helpful had you thought to include that info. Also is the model number you your question posted under correct? If all this is true, you just have a dried up ink cartridge -replace it
