Refrigerators Logo
D
Diana jilwah Posted on Oct 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchen aid freezer clicking on and off ... where the ice maker is...did not connect the ice maker feature...what's the reason for clicking. Thanks
jws1013
Level 3:
  • Master 1,713 Answers
  • Posted on Oct 16, 2019
jws1013
Master
Level 3:
Answers
1713
Questions
Helped
458751
Points
6786
Probably the unit is trying to fill because the on/off bar it down (senses the level of ice in the tray). Lift it up to turn off.
5 Related Answers
A
Anonymous
  • Posted on Feb 18, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Anonymous
  • Posted on Jul 05, 2008
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Anonymous
  • Posted on Sep 16, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Anonymous
  • Posted on Jan 05, 2009
SOURCE: ice maker not working
My chilled water works great but the ice maker is not working at all.
Anonymous
  • 63 Answers
  • Posted on Mar 10, 2009
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Water, but "no ice" in my Kitchen Aid
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Kitchen aid icemaker won't dump
Sounds to me that you need parts or as most Whirlpool/Kitchenais Ice Makers their averagte life is 5 years. Call before purchace to confirm but here is what I have for the complete Ice Maker=> 4317943 Ice Maker Assembly
For much more info click here=> Broken Ice Maker Repair
I will be here if you have any other questions, Thanks, Sea Breeze
utube.png You-Tube video "VCUgA5T5ASw&feature=player_embedded#!" placeholder
KITCHEN AID REFRIGERATOR PROBLEM We bought a used Kitchen Aid fridge YKSRS22Q (1993), the ice maker is not working but water does work. What should we check to see why the ice maker doesn't work?
Ice makers work off of temperature. If it's not cold enough in the freezer it won't work. Check the temperature with a thermometer, it should be 0 to +10F
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 • Dishwashers
Ice Maker not working in Kitchen Aid Superba. Light is blinking constantly on right side wall of freezer. Is this normal?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
44
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
7helpful
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
1helpful
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
