B
Bryan Fenwick Posted on Oct 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new Sky+HD Box-Wifi-2TB has only a single audio output but it does have an optical output. Can I connect this to the Yamaha CRX-D430 or is the optical port on this output only
Franco Dosil
Level 3:
Top Expert:
  • Yamaha Master 10,542 Answers
  • Posted on Oct 16, 2019
Franco Dosil
Yamaha Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379225
Points
178965
Hi Bryan Fenwick, if your Sky + HD Box-Wifi-2TB, has a unique audio output and is an optical type (Fiber Optic), you will not be able to connect it to your Yamaha CRX-D430, because it does not have such inputs , the fiber optic connection you have, is an output of the compactera
You should buy an audio signal converter by fiber optic to audio signal, L R, with RCA
Hola Bryan Fenwick, si tu Sky+HD Box-Wifi-2TB, tiene una unica salida de audio y es tipo optica(Fibra Optica), no vas a poder conectarlo a tu Yamaha CRX-D430, por que no tiene entradas de este tipo, la conexion de fibra ptica que tiene, es una salida de la compactera
Deberas comprarte un conversor de se?al de audio por fibra optica a se?al de audio, L R, con RCA
https://uk.yamaha.com/files/download/other_assets/2/325162/CRX-D430_B-1.pdf
pice
Level 1:
  • Contributor 3 Answers
pice
Contributor
Level 1:
Answers
Questions
0
Helped
166
Points
9
Making more cash just by doing an easy work in part time 0nline using laptop or PC from $18k to $20k. Now its time for you also to get this and start earns 0nline by follow instructions on this web...........www.GeoSalary.com
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 12, 2007
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Anonymous
  • 372 Answers
  • Posted on Jan 31, 2008
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
skotkolr
Scott Hill
  • 558 Answers
  • Posted on Apr 27, 2008
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Anonymous
  • 59 Answers
  • Posted on Sep 24, 2009
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
ameliawang93
wwlvictoria
  • 1001 Answers
  • Posted on Jan 17, 2017
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience.
Amazon com Charm sonic Wireless Portable Bluetooth 4 1 Receiver Wireless...
1helpful
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
My goodmans ld2271d tv has no control. When I set it up with the sky box it comes on but no sound , even on full volume. can anybody help? Could it be stuck on mute?
check the sound setting on the sky box go to setting, then sound. audio out stereo
digital audio out optical (dolby D)
digital audio output hdmi (normal)
digital audio output delay (0ms)
this is how the settings should be digital out put hdmi only works with full HD 3D tvs.
How do get sound surround interface between my HD SET TOP BOX and my Sony DAV-S300. I have seen previous responses and digrams with connection to the Optical in socket on my DAV but my system doesn't have...
http://hd.sky.com/hd-television-equipment/hd-set-top-box/
http://hd.sky.com/hd-television-equipment/input-output-connections/
http://www.ehow.com/how_5890852_convert-hdmi-rca.html
The first two links you've probalbly seen before, they show conncections and connectors. I looked at pictures of your system and it would appear that the only input for video and audio is RCA. I think it has s-video for video only(s-video slightly better). The third link is the only way I can see to get what you are asking. It is an HDMI to RCA adaptor. You would use an HDMI cable out from your set top box to the adaptor then, RCA cables to your DAV-S300. It's the only way I can see. Hope this helps.
Popping noise through speaker when changing channel on sky hd
What make is your HD Box and TV? Assume you are connecting direct to your TV using HDMI, and not though an amp? If you do have an amp, you'll need an optical from HD box to amp to get DD 5.1, and connect your HD box to TV with the HDMI. Have you disconnected any scart connections from the HD box to TV - no longer required unless you really want to watch SD over the scart? Check that the Audio Output in the Sound settings for you HD box is set to Stereo.
Does your TV have individual audio and picture settings for the input source - perhaps you need to tweak these for the HDMI input being used. Do you have another HDMI cable you can use to eliminate a possible dud?
1helpful
How to get surround sound?
Hi, I would recommend using an optical cable from your Sky box to your surround system. The should look like this:
http://files.sandberg.it/products/images/lg/505-39_lg.jpg
1helpful
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
2helpful
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
