It sounds as if you have a defective timer control. Try operating the washer on a different cycle, if it spins on these cycles the mechanical workings are fine it's an electrical switching problem in the timer.
Either the belt broke or the hood switch is not working. Sometimes it could be the contacts in the main control knob but if everything else is working correctly, then check the belt, and the hood switch first.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine. What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
see the next steps and use the common sense: God bless you When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. See There's no cold water.
The typical cycle is; fills to selected water level agitates wash cycle drains wash water spins wash cycle fills to selected water level on rinse cycle agitates on rinse cycle drains rinse water spins final time end of cycle
If the timer gets to the rinse cycle and stops, Check the lid switch for continuity. If no continuity replace the lid switch. If the timer continues through rinse and spin without doing either, replace the timer.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
