20 Most Recent Malber WD1000 Front Load Washer/Dryer Questions & Answers
2answers
Detergent doesn't drain
The rod which controls the flow of water to the various compartments needs to be adjusted. It is not a difficult fix. You can contact Malber usa ([email protected]) and they can "walk" you through it. In the alternative, you can put the detergent in the pre-wash tray without concern.
3/19/2024 6:18:28 PM • Malber WD1000... • Answered on Mar 19, 2024
Replacing Heating Element WD1000
you may call me
Peter Phillips 212-278-0428
8/8/2023 3:31:14 AM • Malber WD1000... • Answered on Aug 08, 2023
Need service for Malber 1000 heating element..
Hi. Mike here. I repair Malbers in the Washington D.C. area. The most likely problem is not the heating element, but the hi-temp (or "brown") thermostat. They cost about $25 and are very simple to install. A "Torx 1.5" screwdriver (asterisk tip) removes two screws, in back, holding top on. Lift off top, and (from the front) see silver-foil-wrapped heating assy. At lower right will be a small philips screw holding a thin wire "hasp" which holds the thermostat in place. Remove screw and hasp (without dropping in machine!), unplug two "quiik-connect" lugs (orange & red wires) and pull out thermostat to the right. New one slips right back in. Replace wires, hasp, phillips screw and top -and you're done! This is 90% sure to fix. The heating element is only about 5% likely.
One last thing ... when re-inserting new thermostat, you'll have to "wrestle" with it a bit, as the tip needs to slip into a tiny (hard to "find") hole. Keep trying, and eventually it'll fit ALL the way in, so the hasp can hold it. To purchase part, call Joel (at Malber): 800-600-8913
Oh yeah, one MORE last thing... That red wire may be burnt a little, or completely burnt in two. Radio Shack and Home Depot sell "crimp-on" lugs (1/4") like these (female). Trim back the wire, crimp a new lug on the end, and push it back onto lower terminal on thermostat. If wire is too short, of course, add a few inches of 16 guage "stranded" (lamp cord). The same stores also sell tubular "crimp-on" wire-connectors (little blue tubes) to join the old and new wires. May God bless.
12/21/2021 6:36:16 PM • Malber WD1000... • Answered on Dec 21, 2021
2answers
Spin cycle won't get up to speed!?
Might be a control board problem. Contact Malber USA at 1-800-600-8913. They will have replacement part and, if the machine is still under warranty, the part is free.
1/22/2019 6:56:55 AM • Malber WD1000... • Answered on Jan 22, 2019
2answers
Spin cycle not working on Malber washing machine, it is on a used boat we just bought and it is in Fort Lauderdale but coming to NY soon, boat broker says he cant locate a person to fix the Malber- an
In New York, call Malber Distribution Corp at 516-323-5299. They can schedule a technician to fix your machine. They've been fixing Malbers for about 25 years. Tell them Mike, in Wash DC, says hi.
1/22/2019 6:50:27 AM • Malber WD1000... • Answered on Jan 22, 2019
Where parts for malber 1000 could be found and ordered
go to the manufactures website and order the spares you need eric
1/17/2018 4:46:18 PM • Malber WD1000... • Answered on Jan 17, 2018
I have a Malber Wd 800, the light turns on, but
Water inlet magnetic valve?
12/3/2017 11:19:24 AM • Malber WD1000... • Answered on Dec 03, 2017
2answers
MALBER WD 800 Features
I have a manual if you wold like a copy.. I can fax it to you
[email protected]
6/13/2016 9:32:06 AM • Malber WD1000... • Answered on Jun 13, 2016
2answers
The dryer is not working and have cleaned out lint liner and emptied water drain
Have you read my question about more info?
3/28/2016 11:17:01 PM • Malber WD1000... • Answered on Mar 28, 2016
2answers
How do I dry clothes
Either hang them up wet or put in clothes dryer
3/18/2016 11:26:31 PM • Malber WD1000... • Answered on Mar 18, 2016
Washing machine user guide teka wdi 1000
Please let me know if you figured out how to use this machine yet. I can't figure it out!
11/19/2015 10:40:14 AM • Malber WD1000... • Answered on Nov 19, 2015
We broke the door handle on our Malber 1000 Can we
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
10/5/2015 11:46:14 PM • Malber WD1000... • Answered on Oct 05, 2015
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen. Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad. You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
3/6/2015 11:47:44 PM • Malber WD1000... • Answered on Mar 06, 2015
2answers
No longer heats during dry
HELLO THERE:
if you have cleaned all of the lint from the filter and still no luck you are goiong to be looking at replacing the heating element.
contact your local appliance repair for this part and a price ok?
best regards mike
3/5/2015 10:35:58 PM • Malber WD1000... • Answered on Mar 05, 2015
How do I dry only
When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point? Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there. At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode. As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly. (You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway) So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
2/16/2015 3:36:00 AM • Malber WD1000... • Answered on Feb 16, 2015
Malber WD1000 Front Load Washer/Dryer Logo
246 questions posted
Top Malber Washing Machines Experts
vince
john h
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Malber Washing Machines
Most Popular Question
dryer not working cleaned out lint liner
  • Washing Machines
