My Whirlpool Ultimate Care II Dryer timer knob has been touchy lately. stops the dryer or restarts if I touch the knob or adjust it back or forwards a little or even pull the knob partly off the post.
Sounds like the knob is not on correctly, or is not the correct knob, or the plate with the numbers on it has moved. When it turns off naturally, does that line up with 'off'?
Ultimate Car
II Dryers are fitted with a mechanical timer that sends an impulse to
the control circuit board to stop running once the set amount of drying
time has elapsed. This is because, should an electronic timer fail, this
would necessitate the replacement of the entire circuit board. Confirm
that the mechanical timer is indeed broken by opening the dryer's door.
If the dryer stops, the circuit board is working fine and is not the
problem. Simply slide off the protective faceplate of the dryer, unscrew
the control board beneath, and flip it over. Connected to the back of
the timer's knob should be a small round device with two wires running
to the circuit board within the body of the dryer. Unscrew this device
from the back of the knob and disconnect the wires. A replacement timer
costs a few dollars and should screw into place without trouble.
Reconnect the wires and put the dryer back together. It should work fine
now.
If you need a new timer the best place ti get it is from Rough River Appliance Repair
Phone number is (270) 230-1818 his name is Charlie and he is the best!
Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
If you find the wire repair it and make sure the wire harness is secure in the provided clips.
You are probably hearing the timer count down, which means the timer is working right. This sounds more like your start switch is out. If you email or callus with your model number, we'll be sure to get the right parts out to you rigth away so you can get this repaired. We look forward to hearing back from you soon. Hope this answers your question.
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
