Has new battery willnot change channel or hdmi
I am making a good MONEY (500$ to 700$ / hr )online on my Ipad .Last month my pay check of nearly 30 k$.This online work is like draw straight-arrow and earn money.Do not go to office.I do not claim to be others,I just work.You will call yourself after doing this JOB,It's a REAL job.Will be very lucky to refer to this WEBSITE.I.... www.amazon78.com
You can order a new remote from ebay or just google the make and model of the tv and remote or you can use a universal remote and pick one up at a local Wal-Mart or Target store. Good luck.
SOURCE: remote control changing channels
Make sure to push the TV button on the remote. some times it will be in the wrong mode ie VCR.
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
SOURCE: my Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
SOURCE: My remote control just stopped working to control
It sounds as if the individual keys on the remote maybe having problems, the cheapest thing is to get a new universal remote. They start at $4.00-$32.00 and will work for most TV's by entering a specific code. Remotes depending on use /abuse do not last forever but at least the replacements are cheap.
