Plumbing Logo
J
Jacquie Hromyk Posted on Oct 04, 2019
Is there a way to connect 1/2 inch copper plumbing pipe to 3/4 inch pex lines? Is there a special connector that can be purchased for such a retrofit?
tim_vance0
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Oct 10, 2019
tim_vance0
Contributor
Level 1:
New Friend:
Answers
7
Questions
Helped
3868
Points
15
You can purchase a reducer 3/4 per to 1/2 copper at Lowe’s, Menards, ACE Hardware, Home Depot.
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jun 03, 2008
SOURCE: LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Jun 04, 2008
SOURCE: PAC L90 leaking oily substance
it leaked all the freon and oil out .
it needs to be vacuumed and oil replenished.
filled with freon.
should only cost you bout 50.give or take
as they use very little freon.
a shrader valve port has to be added to introduce the freon. takes just a few seconds.
Anonymous
  • 234 Answers
  • Posted on Mar 14, 2009
SOURCE: Think I have pinhole leak in 1/2'' copper water pipe
What type of pipe are you looking at?If it is copper then you can fine someone to solder it.If it is plastic pipe with glue joints,then you get some glue call rain and shine,clean first then apply wait a few minutes.But turn the water first.
Anonymous
  • Posted on Apr 30, 2009
SOURCE: replacing headphone connector
My jack plug lead got yanked and broke the wires inside the electronics unit. There are three screws to undo in order to get inside the electronics, one by the cable entry and two very small cross head scvrews in deep holes halfway along the unit. I cut the jack lead on the outside close to the cable entry and drilled out the hole through the cable guide and then poked the jack cable back through the hole into the electronic unit. I was able to solder the three leads to their respective pads. There are five solder pads next to the cable entry. With the cable entry at the top, the middle pad connects to the green cable, the rightmost pad connects to the red cable and the copper connects to a pad about 1 cm down from the rightmost connector. The technique was to tin the ends of the leads with solder before soldering them to the pads. I used a blob of glue from a glue gun to hold the cable in place inside the electronics unit. My plan B if the soldering was not possible was to take a jack plug and lead from an unused set of earpieces and use that lead in place of the original. It would have been much more difficult to replace the lead from the electronics unit to the headset.
Mike
  • 4383 Answers
  • Posted on Oct 11, 2010
SOURCE: I have a leak at
You may have a torn or damaged o ring. Pretty much you need to get a replacement hose from Price Pfister.
The faucet has two cold and hot inlet pipes at the bottom. both need a 1/4" brass male to connect. The water supply valve is 3/4" compression. Where can I find such connecting pipes? Thanks.
If you tried using a typical 1/2 to 3/8 faucet connector such as https://www.homedepot.com/p/3-8-in-Compression-x-1-2-in-FIP-x-20-in-Braided-Polymer-Faucet-Connector-B1-20A-F/100459572, and it didn't work then ignore this answer, else...
Plumbing pipe size can be misleading due to the fact the pipe diameter is based on outer diameter and the inner diameter varies with wall thickness. To determine standard pipe diameter you measure the outer diameter and subtract 1/8".
The typical 1/2 inch pipe has an outer diameter of 5/8" and like wise a a 1/4" inner diameter pipe is a 3/8". So likely the typical faucet connector is correct. But you may have something unusual so FYI.
May 05, 2019 • Plumbing
I got a 2005 homestead rv and the water pipe broke or froze up how can I check and fix it
Water pipes in RV are Pex, which is not the same as PVC. Pex will freeze, but is designed to not burst when frozen. If you have located the broken pipe, it is simple to replace. Using a PVC cutter (looks like cheap shears) cut out the broken piece. Most likely the pipe size will be 1/2 inch. Pex comes in three different colors: white, red, and blue. Most likely the RV pipe will be white, but the color does not matter as the pipe is of the same material. Pex can be bought at stores like Home Depot, Lowes, or other hardware stores. The connector fittings can be bought at the same stores. The simplest to use fittings are the push-on self sealing fittings. There are cheaper fittings, but they take special tools to install them. The estimated cost of a 2 foot distance pipe repair is about $10 to $15. The time required depends on how difficult it is to "get to" the broken pipe.
Hi i got a main pipe bringing in water
I wouldn't put psi any higher and it should run two small homes
Oct 03, 2014 • Water Sport
Fix copper tubing 1/2 " pipe
use pipe cutter to lop off end and sand the last 2-3 inches down with abrasive sand cloth. if you never braised before, i would recomend sharkbite plumbing fittings. comes in 1/2", which is what it looks like you have. it slides onto existing pipe (copper, pvc, cpvc and pex) and makes a seal, while the teeth inside keep it from coming off. there is a ring on the end that you can push in with a specific tool (which comes with some fittings) to remove it. they have extentions, valves, couplings and terminations in sharkbite. they sell them at any home depot. good luck and have fun
Feb 27, 2014 • Plumbing
1helpful
Water through the door has an after taste. We recently had copper plumbing installed, and since then we have gone through three filters, disconnected the water line and flushed 10 gallons of water through...
Sorry to read about your problem, I hope this helps you out.
you must have a large amount of solder resin in your line, thats from putting the joints together on your copper pipe...should have put pex pipe in...may have to run a resin cleaner thru the lines
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1helpful
My Aprilaire is connected to the Hot water line and it stops working in approx 1 month. I just had plumbing work done and my new plumber said the problem it that it should be connected to the Cold Water...
Your plumber is correct your unit should be plumbed with cold water.
Easy fix if you need to do it yourself.
More than likely they have a 1/4 inch line taped into a 1/2 inch copper line near your furnace.
Simply shut off the tap on the undesired line and disconnect the 1/4 inch line.
Install a new tap on the cold water side and reintall supply line to the unit.
Do not remove the old tap on the hot water line simply shut it off because it puctures the line, hence the tap.
5helpful
4answers
Will a compression fitting work on 1/2'' galv. pipe?
They do make a compression coupling for galvanized pipe, but I don't trust them very much. When you unscrew the joint with a pipe wrench just make sure to back it up with another, so you don't start to unscrew the next joint back.
Oct 04, 2009 • Plumbing
5answers
Bathroom plumbing parts list supply line connections cracked (frozen). I have opened the wall behind the bathtub faucet, and can see the problem, but I don't have a clue as to how to repair them. I am...
if you don't know how to sweat copper the best way is cut out the split,and replace with compression couplings and the rite size and length of copper. or you can use sharkbite couplings and pex pipe or copper. sharkbite is the easiest way to go,you just push them together. home depo or lowes carry both
6helpful
4answers
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
