Pool & Spa Logo
w
walter lee Posted on Oct 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to wire a dewalt radial arm saw for dual voltage.
The motor is 110-220 volts. right now the power cord is black to reset button white to on-off switch green to ground. To change voltage it has a DPDT switch. I want to use 220v for 12 blades and 110v for 10 blades but I don't think the present power cord and or connection is correct for this.
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Oct 03, 2019
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567602
Points
3788
110 volt units have a different 3 pin plug. You will need to fit a standard Australian 240volt plug on the cord. Get a sparkie or someone competent to wire it and fit it. The black will be Neutral, the White, active and the green is earth. Make sure the DPDT switch is set to 240 otherwise you will burn it out. I will assume that you are in Australia and using the 110Volt through a step down transformer. You should be able to get an adaptor for the transformer to save having to swap 3 pin plugs every time you want to change voltage supplies.
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Sep 19, 2008
SOURCE: generator plugs doesn't match cord
Hey steve. do you really need 240 volts for 120 v. circuits. the reason you have to have an adaptor plug is because on your 220 volt plug in , 2 of tthose prongs are hot and 1 is ground. for safety you need to get a plug adapter ( a regular 120 volt plug end ) run a ground from adapter to ground on 220 adapter. same with nuetral. you also need to ground your generator. there is usaully a ground lug on the bottom of the gen. Another way. if you dont really need 220 v. is to use both 120v. recepticals on gen. Run 2 chords to tranf. switch. and hard wire it in to switch. another way i did mine . when i lost power in this hurricane. i ran two # 10 chords from my 2 120v. recept on my gen to my breaker panel. when you do this you have to pull the service meter, if you dont when power comes back on it would backfeed through your gen.then i turn all my 220v. breakers i was able to run lights ,ciling fans, freezer, ice box,washing machine and gas dryer , tv's computors etc. . but to do this, you probably need someone that knows what they are doin.
Anonymous
  • 2559 Answers
  • Posted on Feb 09, 2009
SOURCE: Cannot find specs for my DeWalt Radial Arm saw
Here you go.hope this is what you wanted and Please rate this a fixya
Noyb merlin
  • 38 Answers
  • Posted on Nov 24, 2009
SOURCE: dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
Anonymous
  • 144 Answers
  • Posted on Mar 23, 2010
SOURCE: dewalt Radial arm saw switch
try to find someone on craigs list or ebay selling one for spare parts.
bobodavis
  • 7 Answers
  • Posted on Apr 22, 2010
SOURCE: craftsman radial arm saw 113-197751 wiring diagram needed
A friend just inherited a model 113.197110 and we are in the process of trying to restore it. I can draw you the wiring connections if you haven't figured it out yet.
Need a manual for old DeWalt radial arm saw. Serial:60022464. NO model # on the plate.
check this out
http://www.fixya.com/support/t26033757-dewalt_radial_arm_saw_gw1_single_phase
20 Most Recent Dewalt 10" Radial Arm Saw 2 Hp Questions ...
www.fixya.com/support/p3534275-dewalt_10_radial_arm_saw_2_hp_403044_ma
Recent Dewalt 10" Radial Arm Saw 2 Hp 403044-made In Usa - Miter Capacity: 45° R 9.25" questions, problems & answers. Free expert DIY ... Serial:60022464.
Dec 11, 2016 • Dewalt Saws
Dewalt radial arm saw GW1- Is it single phase or 3 phase
if the plug on the cord fits any other outlet in the house it will be single phase
if the cord is cut , then it will have only 3 wires if it is single phase
( active , neutral and ground )
if it has 4 or more wires it will be 3 phase
most saws running a 200 mm blade or around that size and used for home duty will be single phase
the phase notation will be on the plate attached to the motor of the saw
It will read voltage , amperage, watts or hp, phase and cycles
Jan 02, 2016 • Dewalt Saws
I have to replace the power switch on my Delta Shopmaster 10" radial arm saw. I have the switch, which is a Delta 438010170206S Rocker Switch has (4) terminals. I need to know which wire goes where????
How many wires do you have? The switch is probably a 2 pole, On-Off. If you have 2 wires, connect them to two terminals on one side of the switch (use an ohm-meter to find which terminals make-break). If there are 4 wires, connect the black and white power cord wires to different sides of the switch. Then connect the two motor wires to the two remaining terminals. DO NOT CONNECT THE BLACK AND WHITE POWER WIRES TO THE MAKE-BREAK TERMINALS OF THE SWITCH. This creates a short in the power cord and will trip a breaker.
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
2answers
Hi my name is Pat I need the rewiring diagram. So I can rewire my dewalt radial arm saw motor, it is a single phase capicitor motor with built in brake.It`s 120/208-240 volts, 11/5.5 amp, 3450 rpm, 236...
Here's a Google search on the subject:
https://www.google.com/search?q=dewalt+radial+arm+saw+wiring&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 04, 2018 • Saws
I have a dewalt 740 radial arm saw and i was cutting wood (logs, small ones) with my radial arm saw and it jammed a few times, you could hear the motorand the the blade would start. the last time it...
Look for a reset switch/button on the motor. It may be popped out or it may just need pushing. If no reset, I would suspect the start capacitor has been damaged.
The start capacitor is usually under a tube-like cover on the outside of the motor. Disconnect the leads to this and test for its rated capacitance with a multimeter. If it fails the test with the meter, replace it.
Charlie
Aug 29, 2009 • Saws
1helpful
1helpful
3answers
Dewalt 7749 radial arm saw
for the manuals.
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
