So I'm trying to display my PS3 in HD through a HDMI cable onto my 32" ilo HDTV. Now, I know how to change the setting in the Display Menu on the PS3 from standard VGA to display in HDMI. When working properly all you do is change the video source on your tv and it begins displaying in the newly selected mode. My problem is that when I go to do this on my ilo TV the HDMI source menu just keeps saying "No Signal". I've already canceled out the ideas that maybe the HDMI cord is faulty or the PS3 HDMI port isn't working properly because I have another HD compatible TV that I use and it functions perfectly fine in HD display. So I guess the only conclusions I'm drawing now are either my HDMI port on my TV is broken or perhaps there is a lose wire? I'm looking for more ideas on what I can possibly do to try and solve this issue.
Thanks,
Taylor Scott
SOURCE: ilo tv.
Another possible solution is to go to a major online supplier of replacement remote controls, such as http://www.remotecontrolscenter.com which offers replacement remotes for the ILO brand. I've ordered from the site above, and you will receive the exact replacement that you need for your tv as I did with my sony dvd player.
SOURCE: "No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
SOURCE: ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
SOURCE: Ilo 42" Widescreen Plasma TV - Has NO TV
I was told by another tusted repair org. that this brand has to be sent back to Ilo in the original box to them for repair. And that no one has any part parts for this brand.
