20 Most Recent
iLO V27DMBX Television Questions & Answers
Power Cable Replacement
Try ebay. If unsuccessful you may have to convert the plug on your set to a standard one that will work with a normal standard wire.
TV remote codes
press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
Panasonix tx L32S20BA
Check and replace its main power regulator board. Products powered by electricity should be
serviced or repaired only by experienced professional technicians. Any attempt
to service or repair the product by anyone else could result in serious injury
or death. If you are not familiar with electronics, do not
attempt to repair. Whether you suffer
fatal electrical shock. Instead, contact the nearest service centre.
Thin vertical line on LCD tv
Change input device to some other like a DVD player.Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Thin horizontal line of picture
that is a vertical deflection circuit problem. try to check a 470 UF capacitor connected to the vert. yoke coil if it is open or try resoldering the nconnecrtion at the board. if not, try to replace the B+ filter of the vertical amplifier. another is try to chexk if the vertical moscillator is qworking if you know elecrtonics.
Tv do not want to come on
ensure that the socket has power, then test the power cable to ensure it is conveying power. if its not then you can check the fuse in the plug if it has one, if the fuse is ok you can now open the cover and check the fuse in the power supply area. also confirm that the connectors are firmly fitted and test the set while its open.
When I turn on the tv, the sound comes on, but no
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
I hope this will helpout
Is there a fuse in ilo tv. if so where is it
Yes, first unplug the unit then remove the back cover of your tv, then try to follow the ac cord it will direct you to the main power supply, then follow the ac line in the main pcb you will see the fuse their but there are many types of fuse the common types, are the glass and the ceramic type.In order to check the fuse you should have a tester or try to look if it is a glass try to check the thin wire inside if broken, try to replace it but if you see the glass totally burned out do not just replace it. It has a shorted parts commonly the regulator or the bridge type rectifier.
