20 Most Recent iLO 3200 32 in. LCD Television Questions & Answers
I have an ilo tv
Hello
It is very difficut to get a substitute remote control for your ILO TV. Anyway try these codes with your present remote control. These codes are with AT&T U-verse remote for ILO TV. The codes are:
1412, 1435, 1436
If these codes does not work with your ILO TV, buy one AT&T U-VERSE remote control. It will match for it. OK.
2/9/2024 12:16:05 AM • iLO 3200 32 in.... • Answered on Feb 09, 2024
2answers
I have Videocon 32" LCD( VDL32HBA-FLA ) which got screen blank with vertical / horizontal lines and no osd menu
The T'Con board should be suspected. This is a common fault to most brand of LCD TVs. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
6/23/2022 10:56:33 AM • iLO 3200 32 in.... • Answered on Jun 23, 2022
2answers
I need a code for a ilo television to Dish network
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for a ilo TV for our more popular models of remotes and the instructions for addressing the remote to the TV. I hope this information is useful and if you have any further questions please let me know! remote models remote codes 3.0, 3.1, 3.2, 3.4 IR remotes - codes 569, 720, 095, 743, 721, 500. 5.0, 5.2, 5.3, 5.4 IR remotes - codes 569, 720, 128, 834, 729. 4.0 and 4.4 IR/UHF remotes - codes 720, 569, 500, 669, 549.6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 569, 720, 500, 456, 506, 834. 20.0 IR and 21.0 IR/UHF remotes - codes 726, 559, 666, 596, 621, 596, 625.Instructions for addressing the remote to the TV 1. Turn the TV on2. Press and hold down the TV mode button until all the mode buttons light up red.3. Enter the 3 digit code for you TV.4. Press the pound(#) button once. 5. Try the TV functions to make sure it works.
2/23/2019 1:19:59 AM • iLO 3200 32 in.... • Answered on Feb 23, 2019
2answers
My ilo smell like it
The sense of smell is a wonderful thing. Usually when you smell something burning and you shut it off quick enough it can be repaired. When you see plumes of smoke it's usually too late. If you have a reputable repairman he will be able to tell you if it's repairable or not. My gut feeling is, you should bury it in a quiet spot in the back yard. Sorry :(
12/6/2018 7:57:56 AM • iLO 3200 32 in.... • Answered on Dec 06, 2018
5answers
My tv is stuck at one channel.
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
4/16/2018 8:48:35 PM • iLO 3200 32 in.... • Answered on Apr 16, 2018
21answers
Cannot use the direct tv remote to control the volume, on / off, etc.
In used 10463 for my Direct tv remote...it is an Emerson code. It worked on my 27inch Ilo, from Walmart. Good luck.
1/14/2018 7:26:53 PM • iLO 3200 32 in.... • Answered on Jan 14, 2018
HDMI audio lags behind video on iLo 32" LCD television
Check the tvs settings menu. There should be a HDMI sound option which will fix the delay.
11/30/2017 5:00:04 PM • iLO 3200 32 in.... • Answered on Nov 30, 2017
Master volume to high
what kind of tv is it i work for fios and am willing to help you.
7/13/2017 1:53:18 PM • iLO 3200 32 in.... • Answered on Jul 13, 2017
0answers
Hello
Be the first to answer 7/1/2017 10:25:33 AM • iLO 3200 32 in.... • Posted on Jul 01, 2017Be the first to answer
0answers
Olevia 32" LCD TV
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
3/25/2017 4:29:03 PM • iLO 3200 32 in.... • Answered on Mar 25, 2017
12answers
Need customer service number for ilo
First of all, stop bitching about Wal-Mart. If they tell you there's nothing they can do, then there's nothing they can do. You shouldn't complain because you expect Wal-Mart to solve all your problems! 90 days is 90 days, after that they are not ALLOWED to take back your TV, and for those of you whom this pertains to, if it was messed up before 90 days, you SHOULD HAVE BROUGHT IT BACK IN TIME! Oh, and on the reciept piece, what don't you understand about that? How can they prove it's not stolen if YOU didn't save YOUR reciept?? Common sense says that you should have saved it. At any rate, the number you ned to call is 1-216-454-0867. Yes, it's long distance, get over it.
7/12/2016 3:22:59 PM • iLO 3200 32 in.... • Answered on Jul 12, 2016
I took off cable box,turned cable off on tv menu.
I do beleive most tv companies stopped broadcasting over the air. the only way to receive more channels is to take the cable wire that comes out of the wall and then into the tv then auto pragram one more time and see if this helps. One question why would you remove the cable box? if you cancelled cable tv all together you will not get any channels. And like i said before all tv channels are removing there air broadcasting. so rabbit ears are going to be in the past soon. i hope this clarifies the situation.
4/11/2016 7:39:49 PM • iLO 3200 32 in.... • Answered on Apr 11, 2016
iLO 3200 32 in. LCD Television Logo
904 questions posted
Popular Products
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • iLO Televison & Video
Most Popular Question
ilo dpd4210 no picture or sound
  • Televison & Video
