Hi PC Bedwell, check the battery charge, it may be needing to be replaced, likewise, control the charger
I hope you can solve the problem
Regards Franco Dosil
Hola PC Bedwell, comprueba la carga de las bater?as, puede estar necesitando ser reemplazadas, de igual manera, controla el cargador
Espero puedas resolver el problema
Saludos Franco Dosil
SOURCE: communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Motorola Talkabout 5700, 60 second timeout?
The 60 second timeout is a feature which is necessary to keep from burning up the final amplifier in the unit. It keeps the user from ruining their radio. Most radios, including business radios have this feature. Continually holding down the PTT will also run the battery down very quickly.
It would be best to try getting a regular baby monitor.
SOURCE: Motorola talkabout 200
Here is a link to the TA280 manual, which is similar to the TA200, http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Funny thing, I haven't found the TA200 manual in English. Here it is in Czech: http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf If you do a google search, you can find the page and have it translated. I'll keep looking, and if I find it in English, I'll repost.
SOURCE: how to shut off roger beep on motorola mr355r
Here is a link to the user guide. The description is on page two under Talk Confirmation Tones.
http://www.giantintl.com/ContentManage/manuals/Moto/MR355%20User%20Guide%20Updated%20Chart%20FINAL%2004-02-09%20KEM-PK14190-94A.pdf
SOURCE: motorola talkabout sx900 will not communicate
Here is a link to the user guide. http://www.banoggle.com/Products/Motorola/manuals/SX900-manual.pdf Page two will be where you will find most of the instructions. Check your frequency, code and Qt filter. Make certain they match one another identically. If you continue to have difficulties, set the code and Qt filter to zero (or off), as well as the weather alert. Then try the units again. Hope this solves your problem.
Best regards.
