Tom Head Posted on Sep 11, 2019
How do I clear current settings in my Trio - Audio Players & Recorders
My trio stealth will not go pass the trio screen. How do I fix this?
hold your power and volume up at the same time when it comes on release power button wait 5 sec release volume button you will see sevral ways to restart i had to clear data and ues factory restart just follow promts worked for me
Code M4 erro
Service mode, first
1.Press the Utility key.
2. Press the Meter Count key.
3. Press the following keys in this order:
Stop  0  0  Stop  0  1
for security "Stop 9"
In Security, Select Copy Kit
1. Touch "Set."
2. Press the Clear key to clear the current setting.
If the setting is accidentally cleared, press the Interrupt key to
undo the clearing operation.
3. Enter the desired value from the 10-Key Pad.
4. Touch "Current."
5. Press the Clear key to clear the current value.
If the current value is accidentally cleared, press the Interrupt key
to undo the clearing operation.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Changing wire settings
You may change the Wireless pass key from WEP to WPA2 from your Router page.
Please let me know the make and model of your Router, so that I can provide further detailed instructions.
Hope this helps..
Android.process.acore
Go into Settings/Applications/All and find Google Services Framework and clear the cache (if any) and clear data.
Disable DRM Protected Content Storage and Media Storage in your Apps list.
Or if either of those fails, uninstall latest update [until you get to the latest properly working update] or factory reset
Trying to download, Weather Bug App? Tablet says it's Downloading?
Sometimes the store app gets hung up. Go into Settings > Application or Application Manager. Locate your store app. Usually Play Store. Tab it and clear the data and cache. Restart the tablet and try downloading again.
4helpful
2answers
How to unlock a trio stealth pro 4.0 0S if forgot pattern lock
i got a trio stealth about a year ago but now my son lock it and cant find a way to unlock it pattern please any one help me with this thank you so much
Hey my trio is froz how do u fix it
There is a reset switch on all MP3 players located somewhere on the chassis, you are looking for a hole that a safety pin can fit into, once found press and hold for 60 seconds to clear the microprocessor ic, if this fails to work it may be time to replace the player.
The answering machine messages are completely disthorted
Get the manual & check for the settings to clear teh message
www.vtechphones.com/vtechui/support/manual.cfm?manualID=21705 - 27k
 Grubhead
Grubhead
SmartAviator
SmartAviator
