20 Most Recent Mach Speed TRIO Stealth G2 10.1" 16 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen Questions & Answers
Try to clean camera objectiv.
Mach Speed TRIO... | Answered on Mar 05, 2016
Hi There.
Under Settings, there should be a scetion called "Backup and Reset" - The Factory Reset option will be in there.
Hope this helps!
Mach Speed TRIO... | Answered on Jan 14, 2016
Go to setting turn on Wifi and search in a few minutes it should show available networks connect to your network and if protected enter password from router or modem. Will will tell you if it is connected or trying.
Mach Speed TRIO... | Answered on Jan 02, 2016
If your not getting any indication lights on tablet could be wrong USB adapter transformer. It could also be a bad wire from adapter.
You did not indicate type of tablet or adapter you are using. Worst case you have a bad battery in table and would most likely ha e to be sent in for repair. However if you have a cell phone USB charger for a car try plunging in tablet in and see if it charges. If it does get a new adapter with higher amp than the one your using. But beware the batteries can only be charged to a max amp see web site for you tablet for recomindation.
Check XDA developers
Mach Speed TRIO... | Answered on Oct 02, 2015
You are asking "Why did power button collapse"? Probably because it is a cheap, low quality product..
You can get it from Amazon for an amazin' low price
Mach Speed Trio TRIO STEALTH G2 7 Inch 2 GB Tablet
Should check while and where you can get service to your device. If still on warranty, it's obvious that it's a failure from factory so you should look up if you have near an authorized repair service
Mach Speed TRIO... | Answered on Sep 10, 2015
Normally the Google Play store is pre-installed on these tablets. Check your apps list - it may just not show on the top screen. If you have lost it somehow, try How to install Google Play Store app manually
Mach Speed TRIO... | Answered on Jun 15, 2015
You got one of those no name chinese made tablets, if the reset to factory defaults it is not working there is a slim chance to load a new firmware.
Mach Speed TRIO... | Answered on May 14, 2015
mine either but ...... that means that your battery bar is not full even though it says is it.Or ur tablet does not hold its charge
Mach Speed TRIO... | Answered on Mar 20, 2015
Your tablet is not charging , those are the symptoms of an empty battery
Mach Speed TRIO... | Answered on Mar 18, 2015
Unfortunatly, your launcher is corrupt. The only answer I can see will be a complete restore to factory defaults. Your apps should reload once you sign back on to the app store, be sure to use your original signon and password combination. I had to do this once and everything seemed to follow up.
Good Luck.
Dean
Mach Speed TRIO... | Answered on Mar 06, 2015
try if you can delete all not necessary files from startup sequence, and if you can download upgrades for the system, if you can, upgrade to android 4.1.
if not then go to this site and try to flush it:
http://forum.xda-developers.com/showthread.php?t=1831257
have look at the flics and follow comments as well:
https://www.youtube.com/watch?v=ZcOqELRABDs
https://www.youtube.com/watch?v=QaGCIItG3NA
hope this will help you - do not forget to vote... by the way, i did find them on amazon for $45.00 new...
Mach Speed TRIO... | Answered on Feb 26, 2015
Mach Speed TRIO Stealth G2 10.1" 16 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen Logo
68 questions posted
Top Mach Speed Tablets & eReaders Experts
 Mike M
Mike M
Robert Graf
yobo007
yobo007
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Mach Speed Tablets & eReaders
Most Popular Question
cannot get tablet charge am trying
  • Tablets & eReaders
