S
Scott Posted on Aug 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i hook up a kenwood equlizer to a kenwood receiver
David Payne - Geek
Level 3:
Top Expert:
  • Master 2,014 Answers
  • Posted on Aug 19, 2019
David Payne - Geek
Master
Level 3:
Top Expert:
Answers
2014
Questions
0
Helped
55562
Points
545411
1 Related Answer
shajanrs
Shajan RS
  • 890 Answers
  • Posted on Jul 04, 2011
SOURCE: I need assistance in how
I'm sorry for the difficulties you're experiencing in connecting Bose Equalizer to the Yamaha Receiver. To enable use with all of your A/V components, EQs (and other external sound processors) require that the audio signal flow out of the receiver, through the equalizer, then back into the receiver before it's amplified and sent to your speakers. To add an equalizer to your system, you'll need a receiver with either a tape monitor loop or a preamp-level output/main-in loop.
Unfortunately, the Receiver does not have both these inputs. If your receiver doesn't have a tape monitor or preamp-out/main-in loop, you can still connect a graphic EQ for use with one specific component in your system. In that case, you can connect the equalizer to the MD tape out or CD out. But it will only work according to the input connected to the MD tape In and CD in jack of the Receiver respectively.
Thanks for understanding. Please let me know if you require any clarifications.
How do i hook up a Kenwood VR 605 surround sound receiver to a graphic equlizer
It will be between your outputs for the speakers before going into your television . Follow wiring instructions.
2answers
If i hook up an equlizer to my Kenwood receiver with the tape monitor inputs and outputs will my surround sound still work
Tape (audio) in, is input.
Tape (audio) out, is output to record what the receiver is playing.
This won't work, to connect an equalizer.
Receivers have a zero out and in and are jumpered until adding what you want to add, that's where equalizer or amp, pre-amp goes
What would be wrong with my kenwood-krf-v5100d and the front right and left speaker out lets are not working propaly sound dose come out of them but it is real low and when you go to turn them up inde
There is a balance option. Find the manual for this player and look for balance. You are looking to change it to 0 so that it plays through all of your speakers at equL volumes
How do i hook uo a kenwood m1 amplifier to a kenwood receiver
Hello
What are the model numbers of the Kenwood devices do you want to hook up with?
Can i hook up my cd player which is a kenwood cd-323m to a vr507 kenwood receiver
hi,
Yes you will be able to connect the same. Connect the line output of the KENWOOD CD 323M to the CD input of the KENWOOD VR507 receiver using a stereo RCA cable. The picture of the cable is added.
ok
1helpful
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
2helpful
I have dish network and a dvr and cd disc changer i need to hook up to my kenwood vr-615
Hi shelleyhelle, I was reading over your post and see where you want toconnect the CD disc changer and you want to connect it to the Kenwood VR-615. Iwill send this link, http://www.retrevo.com/support/Kenwood-VR-615-Receivers-manual/id/480bh228/t/2/and it will help with the setup for the Kenwood VR-615 receiver.
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
