20 Most Recent Kenwood DP-J2070 CD Player Questions & Answers
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Kenwood DP-J2070... | Answered on Jan 30, 2008
It will be between your outputs for the speakers before going into your television . Follow wiring instructions.
Kenwood Audio... | Answered 29 minutes ago
Tape (audio) in, is input.
Tape (audio) out, is output to record what the receiver is playing.
This won't work, to connect an equalizer.
Receivers have a zero out and in and are jumpered until adding what you want to add, that's where equalizer or amp, pre-amp goes
Kenwood Audio... | Answered Yesterday
Press the power on on the remote.
Kenwood Audio... | Answered 3 days ago
pl go through the manual which link is attached herewith Kenwood RXD V323 Manuals
Kenwood Audio... | Answered on Jul 06, 2019
pl go through the user manual for your ready reference Kenwood RXD V323 Manuals
pl check the user manual from the link for ready reference Kenwood RXD V323 Manuals
Hello Educare Shalom, to be able to handle the volume of your kenwood tuner kt 45, you should connect a stereo potentiometer of 50 kOhms Linear in the output signal or connect it to a sound mixer, to be able to regulate the output level
Hola Educare Shalom, para poder manejar el volumen de tu kenwood tuner kt 45, deber?as conectar un potenciometro est?reo de 50 kOhms Lineal en la se?al de salida o conectarlo a un mezclador de sonido, para poder regular el nivel de salida
Kenwood Audio... | Answered on Jun 15, 2019
Hello Kamran, I sent you the link to download the manuals of your Kenwood RXD-V323, so you can check the numbers of the belts you need
I hope it helps you
Greetings Franco Dosil
Hola Kamran, Te envio el link para que descargues los manuales de tu Kenwood RXD-V323, para que consultes los numeros de parte de las correas que necesitas
Espero te sirva
Saludos Franco Dosil
https://www.manualslib.com/manual/950090/Kenwood-Rxd-V323.html#product-RXD-V323
Download manual
Hello Kamran, the Kenwood rxd-v323, does not have an echo option
Hola Kamran, el Kenwood rxd-v323, no trae opcion de eco
Kenwood RXD V323 Service Manual
Hi David, if your Kenwood does not turn on, check the power input fuse, to locate it, you should remove the lid
If the fuse is burned, replace it with only one of equal value, to avoid serious damage, if you change it and it starts to burn, look for a specialized technical service
I hope you can solve the problem
Hola David, si tu Kenwood no enciende, revisa el fusible de entrada de energia, para ubicarlo, deberas retirar la tapa
Si el fusible esta quemado, reemplazalo solamente por uno de igual valor, para evitar graves da?os, si lo cambias y se vueve a quemar, busca un servicio tecnico especializado
Espero puedas resolver el problema
Kenwood Audio... | Answered on Jun 13, 2019
Hello JoncoteO, if one of your Surround speakers does not work, you can not use the Front B speakers connection as a replacement
You should check if the output of your Kenwood is wrong or the speaker is wrong
Try connecting the Surround speaker that does not work, in the Surround output of the Kenwood that works, if you listen to it, well the problem is in the equipment
If you do not hear it, the speaker has the problem
I suggest you repair it, since you could have more damage
Hola JoncoteO, si uno de tus parlantes Surround, no funciona, no puedes usar la conexi?n de parlantes Frontales B, como reemplazo
Debes comprobar si la salida de tu Kenwood esta mal o el parlante esta mal
Prueba conectar el parlante Surround que no funciona, en la salida Surround del Kenwood que funciona, si lo escuchas, bien el problema esta en el equipo
Si no lo escuchas, el parlante tiene el problema
Te sugiero que lo repares, ya que podr?as tener mayor cantidad de da?os
Espero puedas solucionar el problema
https://data2.manualslib.com/pdf2/29/2871/287046-kenwood/krfv5010.pdf?17d98b099c8a488d5135daf8097a974c&take=binary
Hi Michael, if your Kenwood CD 204 can play in random mode among the 5 CDs, you have the Randon button, for that function
On page 17, he explains the Randon function
I sent you the link of the user manual so you can download it
I hope you can solve your need
Hola Michael, si tu Kenwood CD 204 puede reproducir en modo aleatorio entre los 5 CD, tienes el bot?n de Randon, para esa funci?n
En la pagina 17, te explica la funci?n Randon
Te env?o el link del manual de usuario para que lo descargues
espero que puedas resolver tu necesidad
https://data2.manualslib.com/pdf/9/862/86192-kenwood/dpfr3010.pdf?e84121e9d1645b7418a0352ba4d72dd1&take=binary
Kenwood Audio... | Answered on May 12, 2019
Hello Rob, I'm looking for the Kenwood A65 user manual and I can not find it, I understand that you are looking to interconnect your equipment and be able to listen
I suggest you send me the list of equipment that you want to connect to the A65, please indicate your brand and model so you can generate an idea of interconnection and so you can solve your need
I am going to send you the link to download the service manual, in the first pages, the rear panel of the A65 appears, which will serve as a reference of where your equipment would be connected
I await your comment about your equipment
Hola Rob, estoy buscando el manual de usuario del Kenwood A65 y no lo encuentro, entiendo que lo esta buscando para interconectar sus equipos y poder escuchar
le sugiero me env?e el listado de equipos que quiere conectar al A65, por favor indique marca y modelo as? puede generar una idea de interconexion y as? podr? resolver su necesidad
yo le voy a enviar el link para que descargue el manual de servicio, en las primeras paginas, aparecen el panel trasero del A65, que le servir? de referencia de donde ir?an conectados su equipos
Espero su comentario sobre sus equipos
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-A-65-Service-Manual.pdf
Kenwood Audio... | Answered on May 08, 2019
Popular Tags
5 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
playing cd rw audio cds kenwood dp j2070
  • Audio Players & Recorders
