20 Most Recent Kenwood KD-291RC Turntable Questions & Answers
2answers
My KD-291RC has power but my turntable wont turn
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
12/17/2014 12:13:12 AM • Kenwood KD-291RC... • Answered on Dec 17, 2014
3answers
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
6/14/2014 10:29:40 PM • Kenwood KD-291RC... • Answered on Jun 14, 2014
manual
0answers
2answers
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
4/19/2012 8:33:00 PM • Kenwood KD-291RC... • Answered on Apr 19, 2012
2answers
Kenwood turntable cover hinge replacement
Yes they can be replaced.
Contact the store you purchased it from or ask where they have repairs done. They should be able to order the parts for you.
6/22/2011 8:06:55 PM • Kenwood KD-291RC... • Answered on Jun 22, 2011
Have Kenwood P25 record player
I can't find either model you mention anywhere but a turntable without a built-in PHONO preamp will require an external on to drive any input not marked explicitly for PHONO.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
5/9/2011 4:01:03 PM • Kenwood KD-291RC... • Answered on May 09, 2011
Hi Mines a Kenwood KD 48F
That's pretty simple, you can see how put the belt in the correct place in this video:
http://www.youtube.com/watch?v=3c1NcRvM9wc
3/19/2011 8:59:56 AM • Kenwood KD-291RC... • Answered on Mar 19, 2011
I have a Kenwood KD12R turntable. How do I set the
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
2/15/2011 11:29:18 PM • Kenwood KD-291RC... • Answered on Feb 15, 2011
Hi, I'm trying to refit
me 2
1/24/2011 6:46:10 PM • Kenwood KD-291RC... • Answered on Jan 24, 2011
Hi, I need help in finding
You need not have to check for Kenwood but many cartridges are suitable to be fitted on to this model .
Please find help to fix them and choose a cartridge/stylus accordingly.
click on Stylus
11/25/2010 7:44:11 AM • Kenwood KD-291RC... • Answered on Nov 25, 2010
Kenwood KD-491F belt come off How do I put it
You have got to lift the table on which the vinyl is placed underneath you will find the belt laying loose on the bottom of the table is a pulley on you fit the belt then on the right hand side or rear is the pulley on the motor which the belt also has to be fitted then carefully lower the so as not to let the belt come off again this should provided the belt is not stretched or snapped then it will have to be reaplaced
10/11/2010 7:39:51 PM • Kenwood KD-291RC... • Answered on Oct 11, 2010
I have a kenwood full automatic turntable KD-67F
First of all you will need an amplifier, because a turntable has no sound power and its impedance needs to be balanced by a phono input, often found on a receiver or an amplifier. Then you will connect the speakers to the receiver or to the amplifier. I believe that a good start would to buy an old cheap stereo receiver, which has phono inputs, where you connect your kenwood turntable. Hope this will help. Flavio/Brazil
9/18/2010 3:02:28 AM • Kenwood KD-291RC... • Answered on Sep 18, 2010
Kenwood KD-291RC Turntable Logo
43 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
fixing kenwood kd 491f turntable
  • Audio Players & Recorders
