SOURCE: Water runs from out the detergent dispenser on my front loader
Try pulling the drawer out again and look in the hole. Look on the bottom for detergent or softener piled up and allowing the water to come out the door or anything clogging the tube in the back of the hole. Look on the top, there are a bunch of little holes, make sure none of these are clogged, clean with a toothbrush and sewing pin if clogged. Take the drawer completely apart and clean thoroughly, check for any cracks. If nothing is found here Take the lid off with the 3 screws in the back and push the lid toward the back of washer and lift off. Run the washer and check for the leaks with a flashlight. DO NOT TOUCH ANYTHING ELECTRICAL. As there is a shock hazard with the lid off.
Thank you
