I Donot hear the sound in my Compaq C700 Laptop
I assume you tried other headphones and I also assume you tried all the 3.5mm jacks, just to be sure. Assuming this is true, then the headphone jack itself is the issue. make sure the plug goes ALL the way in. if it sticks out by just a few millimeters, then that means there is something stuck in the hole itself, and not allowing the jack to work.
you said...
"when i connect external speakers its working fine.But when i connect
the headphone with mic.i'm anot able to hear nothing from the headphone"
If the speakers are working ok, and the headphones are not, then it is an issue with the headphones. It has to be. There is no logical reason for external speakers to work and headphones NOT to work, when they are basically using the same jack. make sure the green jack goes to the headphones and the pink one goes to the mic.
Fredtmccoyjr.Thanks for your Solution. How ever, when i connect external speakers its working fine.But when i connect the headphone with mic.i'm anot able to hear nothing from the headphone.... If the speaker is working fine then headphone must work. but that is not the case.I'm looking for more suggestions as this issue looks strange....
Check whether the Suitable audio drivers are installed
