SOURCE: Own a Moen 87888 kitchen faucet. The handle has
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
SOURCE: handle on moen kitchen faucet is loose after
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
