Panasonic KX-TG6021 Cordless Phone Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen said move closer to the base unit but cannot register
My TG6052 cannot be registered again after the the heavy rain with thunder
Anonymous
Level 2:
  • Expert 80 Answers
  • Posted on Aug 31, 2009
Anonymous
Expert
Level 2:
Answers
80
Questions
0
Helped
67641
Points
130
Try powering down every thing including taking the battery out of the headset. power it all back up and try it again. if that does not work most likly during the storm your base station suffered a fatal surge and it toast.
mj
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Error message when registering the handset with the base unit
you can contact the service provider.........
My panasonic kx-tg4321bx didn't give connectivity response rather than it gives a message "No link to base. Move closer to base, try again"
Well, you could move closer to the base, or try this: RE REGISTER the HANDSET. That works every time when our cordless goes stupid.
Carl
5helpful
2answers
Phone displays a message saying no link to base when it is closer to the base?
Following may be the cause for getting no link to the base.
1. The handset has lost communication with the base unit.Move closer to the base unit, and try again.
2. Confirm that the base unit’s AC adaptor is plugged in.
3. Raise the base unit antenna.
4The handset’s registration may have been cancelled .Re-register the handset.
To Register, follow the below steps.
Headset: Press MENU and then press ‘0’ ‘0’
Base unit: Press and hold HANDSET LOCATOR until the CHARGE indicator flashes.
(After the CHARGE indicator starts flashing, the rest of the procedure
must be completed within 1 minute.)
Handset: Press OK, and then wait until the handset beeps.
Your handset is registered to Base unit.
Thank You
1helpful
2answers
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
No dial tone it says no link to base,move closer,try again even when it is in the base
it needs to be registered with the base on phone go to menu scroll down til you see register, registration, register base, sect it, then it will tell you to set it on base, after that wait a few minutes til its done, pick up phone, you should now have a dial tone, also if you have your manual, look up how to registar base, it might be easier instructions there.
2helpful
2answers
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
